Ford's 'better' idea, NOT
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: Ford's 'better' idea, NOT
    Posted: 02 Jul 2025 at 7:58am
Seems back in '97ish Ford decided to save 2 cents per truck and NOT locktite 2 bolts. The bolts that hold connect the shift lever to the cable that goes to the tranny. Seems after awhile, they get loose. The warning signs are wonky shifting and won't-start-in-park. In my case it was the 'wonder where this T30 Torx bolt head came from' ?? Turns out it's the head from the right side bolt that has been sheared off from using the shift lever for the past 1/4 century.......
Going to be 'fun' getting the  'headless bolt' out of the hole, cause if you remove the left bolt, there's a spring under that plate that'll fall out.
This would be a 10 minute job IF I didn't have to crawl under the dash, bend arms into unnatural positions , try to see with bifocals and best of all ,tossed my back out big time.More 'fun', the left side has a fishing line attached that goes to the PRNDL on the dash !
I did manage to tighten the left bolt, shifts great, starts in park ! so I figure I've bought myself some time.
sho-man1 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote sho-man1 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2025 at 8:04am
I had that on my 97 F150, then the 99 F250 started exhibiting same sloppy shift lever.
Red loc-tite since 2017 on the F250.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2025 at 8:30am
wonder if they fixed that a couple years later ?? ... I had a 2001 and a 2002 with 250K miles each and not a problem.... ?
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2025 at 9:05am
my 95 F-350 did that crap, had to lay in a parking lot in about 2” of water in a rainstorm to get my truck to crank, wasn’t my best day at work!, damn sure got a drop of blue on them that night when I got home
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2025 at 1:58pm
So this is a surprise to you?? Ford has been cutting corners and pinching pennies since the early 1900s
WF owner View Drop Down
Post Options Post Options   Thanks (2) Thanks(2)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:27am
...and the other manufacturers haven't been?
Maybe that's why Ford was able to pay back all their government loans when the others didn't?
This page was generated in 0.551 seconds.
