Ford steering column |
bobkyllo
Joined: 14 Sep 2009 Location: minnesota Points: 1569 |
Topic: Ford steering columnPosted: 18 May 2021 at 6:31am |
So I've got a customer that will go no other place but me. Any ways he has brought me a 1996 e150 van. The bearing is gone from the steering column. He went to the junk yard and got a different column but it's missing the cruise feature and the air bag.
I was doing my homework on this job before it shows up in a few days. It looks as if the bearing closest to the wheel is the one that goes bad. Now I've had columns apart before for different reasons such as multi function switched, air bags, etc. So that party isn't new to me. This bearing removal would be though. Have any of you had luck removing the bearing with the column still in place an assembled for the most part? Or is this a stupid idea on my part? I had figured a simple little bearing had to be much cheaper then a completely column replacement. |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 18 May 2021 at 6:38am |
Aren't you suppose to jack up the radiator cap and install a new van under it on Fords?
Joined: 11 Sep 2009 Location: illinois Points: 90812 |
Posted: 18 May 2021 at 9:03am |
Bob... i have never done it.. but this guy says you can pull the bearing with the column in place if you work at it.... look at the 45 second mark..
