Ford SD auto tranny ? |
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Topic: Ford SD auto tranny ?Posted: 07 Jun 2019 at 5:46pm |
I run a 2005 F250 with 5.2,4x4 and a Reading service body. Truck has 159,000 miles as of tonight. I have noticed in the past 3 months that the tranny will drop into O/D around 45 MPH. I didn't think much about it until a slight acceleration made the engine stumble HORRIBLY until I stomped on the pedal to make it upshift. No codes on the display as of yet, but am curious of what might be coming my way besides the cam phasers
![]() Thanks
Joined: 11 Sep 2009 Location: illinois Points: 90808 |
Posted: 07 Jun 2019 at 9:02pm |
old dirty transmission oil does funny things... I like to remove the pan, clean and replace 5 ( of the 13 quarts) every 50,000 miles... At 159K I hope the trans oil has been flushed or cleaned out at least once.. Probably ready again.. If it has NEVER been done, you got a lot of CRUD floating around the the solenoids and engagement spools. ........... and the motor is a 5.4 with Variable Cam Timing as you said.
FREEDGUY
Posted: 07 Jun 2019 at 9:19pm |
Yes, 5.4, I still have the 5.2 engraved in my head from numerous parts needs for the '95 Dodge Ram that I owned previous to this (although it got 6 MPG better performance with the same payload). Sadly the tranny was completely flushed 20k miles ago when a tranny cooling line rotted off of the radiator
. That was NOT a cheap fix .Thanks for the reply,I was leaning toward an electronic issue for some reason. |
shameless dude
Posted: 08 Jun 2019 at 9:58pm |
if you are gonna drive around (like city driving) drop the tranny lever down a notch into "drive", constant slower driving will have the tranny shifting in and out of OD, soon it won't work in OD. it'll be burned up.
FREEDGUY
Posted: 08 Jun 2019 at 11:15pm |
Shameless, my selections on the display are P/R/N/D/3/2/1. I can push a button on the end of shifter into "tow" mode but that locks me out of 5/6 gears. This issue has just developed in the past 3 months. There is no "hunting" for gears at lower MPH, once it gets into O/D at less than 40, I have to stomp the accelerator pedal to force it to up-shift.
