Ford or Cummins
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Topic: Ford or Cummins
    Posted: 08 Dec 2013 at 10:45pm
Just getting some opinions. Our club just passed new rules regarding alcohol tractors. 385 ci. max. Wondering if I should build a Ford 8000 with 4.2" bore (362 ci), or a 5.9 cummins with Allis sheet metal, which is allowed. I do have an 8000 kicking around, but I'm not stuck on it, I'd rather have an AC! LOL!! Just wondering what motor would be the best, have the most head flow, etc. Thanks!!
blue924.9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2013 at 8:10am
i dont know about the ford, however i know you can get anything everything and more for a cummins
hi my names dan, I am a young guy. i have a problem, i prefer my tractors orange and my clutches mechanical, thanks for letting me share
Bob C IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2013 at 11:56am
Just my opinion... CUMMINS! parts are easy to get
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2013 at 7:47pm
This would be a good question for pull off dot com.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2013 at 8:00pm
The base block on both wouldn't be that hard to find it the alchohaul pieces and ignition parts... I'd like to do a 301 Allis on gas and turbo..
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2013 at 8:28pm
I think the ford has a little advantage. I've worked on the cummins heads and currently have a ford truck head for a LLSS that I need to get working on. I just think the ford will have an advantage with a better head, room for larger valves. The cummins has a high swirl port which may tend to seperate the fuel more than the ford head will. Both are going to be good engines to start with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2013 at 6:48am
I agree with you, wi50. The ford head is big. So you think it will flow more?? My Allis roots are clouding my judgement! My ideal would be the Cummins with AC sheet metal, if it would be competitive. Particularly D21 sheet metal!
This page was generated in 0.377 seconds.
