Ford Lug Bolt ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Ford Lug Bolt ??
    Posted: 17 Dec 2021 at 5:31pm
I run an '05 3/4 ton, my dad runs an '11 3/4 ton pick up. Today, a co-worker was showing off his new tires on his '11 Ford 3/4 ton van. His van only has 7 lug bolts ConfusedOuch ??  my 05 has 8 and my dads '11 has 8 ShockedShocked ?? What's the deal ??  Are vans on a different load rating or is Ford making big $$$ on saving a lug bolt/nut per vehicle ??
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2021 at 7:56pm
Probably both. I now vans are available in 1/2, and 3/4 ton versions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2021 at 8:25pm
Ford came out with that abortion long ago
Knew several guys bought light 3/4t trucks had seven lug wheels and nothing back then years ago as to aftermarket for them
Edited by DMiller - 17 Dec 2021 at 8:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2021 at 9:08pm
YEP... a LIGHT DUTY 3/4 ton... Combination of a 1/2 ton with 3/4 ton axle parts with special hubs/ wheels. .......... only a few years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2021 at 6:17am
Had one of 'them' show up one day...man I counted the nuts several times, thought I needed new glasses.... dang silly..
course ONE of my '67 Mustangs  was 4 bolt, the other 3 were 5 bolts...........
Never ever understood WHY Cavaliers were 5 bolt, seems a waste of material and money...
JohnColo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnColo Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2021 at 10:14pm
Six cylinder Mustangs and Falcons had 4 bolts, V8's had 5 bolts, probably enough savings in brake parts to cover having two sizes, but still...
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2021 at 1:28am
i'm with Jay...a fellow i know has a ferd pickup with the 7 lugs...had to count a few times myself, and when i asked him about it, he hadn't noticed either since buying the truck!
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2021 at 9:39pm
When ferx first came out with that, I had a guy working for me,a dang good little tire man, but his hair was a little thin on top. I walked by him and ask him where the eighth lug but was. He looked around for a while and them counted the bolts. He came over to me and made sure I knew the dang thing only had 7 lug bolts on each hub. I knew that, I was just thinking about him the other day. I havn't seen him since he went to work for Firestone. He was a good worker.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2021 at 12:56pm
Ahhh - but remember back when there were left and right handed lug nuts on vehicles and rims would not interchange like Buick and Olds because Buick had a alignment stud on the drum which other GM didn't have
  Now it's offset (depth or rim) that has changed , or like my 73 Olds rims would fit my 65 Olds 442 but the early rims would not fit front of 73 because disc brakes would not fit inside the rim .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2021 at 1:21pm
Still remember the adage Righty Tighty Lefty Loosey EXCEPT on Chrysler and American motors, plus most ton and up Trucks lug nuts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2021 at 5:29pm
My co-workers van is a 2011 model year Ouch. What's the "few" years break down ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2021 at 6:44pm
Google can tell you...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2021 at 7:13pm
1998 - 1999 they were called "F250 LIGHT DUTY"
2000 - 2008 they were called "F150 - 7700#"
2009-2014 they were called F150 Heavy Duty.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2021 at 7:46pm
The "7700" refers to 7700 lbs GVWRating versus 6250 lbs load rating on a std F-150. Heavier axles and brakes on the 7700 lb package.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2022 at 10:15pm
any update, FreeGas ?
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2022 at 9:03pm
Question: were you looking at the hub cap or the actual wheels? Because Ford has a hub cap that has seven dummy lug nuts on it that they used on 3/4 trucks and vans?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2022 at 8:04pm
