Ford Guys...Remote Start
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Topic: Ford Guys...Remote Start
    Posted: 10 Mar 2025 at 4:15pm
Hi Guys,
  I've got a 2015 F150 and the remote start just quit working.  I started it at home and it worked.  Went to visit my sister and when I was going to leave it wouldn''t work.  I pushed the buttons and the lights blinked and the horn sounded.
What should I be looking at to fix it?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2025 at 4:27pm
Here is the sequence of event in order.. Sometimes if i delay too long between the "push this button, then that button" , or 2019 FLEX does not start......the HORN is not part of the sequence.. Horn is a signal that means NO START..
To remotely start your 2015 F-150, press the lock button on your key fob, then press the remote start button (the button with the 2x icon) twice within 3 seconds
The vehicle will start, and the exterior lamps will flash twice.
Here's a more detailed explanation:
  • Press the Lock Button: First, press the lock button on your key fob to lock all the doors.
  • Press the Remote Start Button Twice: Immediately after locking the doors, press the remote start button (the one with the 2x icon and a rotating arrow) twice, within a 3-second timeframe.
  • Visual Confirmation: You should see the exterior lamps flash twice, indicating that the remote start command has been received and the vehicle is starting.
  • Horn Indication: If the system fails to start, the horn will sound unless Quiet Start is enabled.
  • Vehicle Operation: The vehicle will run for a pre-set time (5, 10, or 15 minutes, depending on the setting).
Edited by steve(ill) - 10 Mar 2025 at 4:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2025 at 4:28pm
Check one of the 3 fuse panels for a blown fuse. Hopefully you HAVE the pristine manual in the 'glove' box. They should show where the fuses are and what they power. Hopefullly one is labelled 'remote start'.
Since the horn beeps,lights flash  is the signal to the 'starter system' that isn't making the trip. The 'control box' should be OK.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2025 at 4:31pm
also try standing 20 ft from the truck instead of in the house.. see if that works...
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2025 at 4:49pm
Maybe check the battery in the key fob too.
Steve in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in MI Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2025 at 5:24pm
if you have a check engine light on the remote start won't work , at least on my dodge it wont
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2025 at 8:08pm
   Remember - Ted said it was a 2015 F-150
Teds Truck has probably heard all the Tariff News going around.
It realizes that when Canada stops shipping that 50% of Canadian
    Manufactured Truck Parts and that 100% of rolls of Aluminum to Stamp
   out all that Ford Pick-up Sheet Metal, Ford Manufacturing Trucks will cease.
Those few remaining F-150's, one's like Ted's, will become Collector Classics.
             AND MORE SOONER THAN LATER
       How does that Classic Song go?   Oh Ya   "LEAN ON ME"
    G
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2025 at 4:51am
    G
You forgot check the antifreeze, gaREE!  Politics belongs downstairs, and your hatred is showing again...Wink
And did I hear a request?LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2025 at 5:12am
Can attest to this one.  2017 Exploder, fob would Unlock doors or Lock them, would NOT open rear hatch or start car, was battery getting weak.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2025 at 8:29am
2015 is 10 years old........... battery change is a GOOD idea, even if not the problem.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2025 at 9:43am
Ya I guess you're right Dave, but it just seemed so fitting! LOL
   Funny nobody asked Ted if he still had the 2nd Remote that he could give it a try.
G
