Ford F-53 a/c
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Topic: Ford F-53 a/c
    Posted: 20 Sep 2022 at 9:04am
went out yesterday driving north on I-35.
134a is within range, belt is intact. Checked all fuses I could locate.
Compressor clutch will not engage when pushing the a/c button on the dash. Any advise would be appreciated. This chassis is under a class A motorhome.
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2022 at 9:28am
My F350 was blowing hot air ever now and then, friend showed me a vacuum like prone to cracking, he cut about 1 inch off it and put it back on, it's worked fine since, I don't know the name of it but zap me your cell number and I'll take a picture of it and send it to you in a few, I don't know if that's your problem but if that line leaks the clutch won't come on, here's my cell 314-791-0276
sho-man1 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote sho-man1 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2022 at 10:05am
My e99 F250 SD with 7.3 had the compressor drop out. Pressures all normal.  One of the  truck forums said to check the magnetic clutch on the compressor for shims, removed one and now A/C works all the time(only had one shim).
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2022 at 11:44am
In reference to Show Man’s post if you can get to the compressor with the engine running tap the clutch with a hammer real quick and see if it engages, if so remove the clutch and remove shim and reinstall clutch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2022 at 12:43pm
first you need to measure the voltage on the wire at the clutch.. If you HAVE 12 volts and the clutch will not engage, then the AIR GAP is too big as mentioned.. If you DONT have 12 volts, there are other safety switches ( HI PSI-- LO PSI-- fuses) that the  "button" sends the power to, before it gets to the clutch..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2022 at 5:26pm
When ignition is on, but engine is not running, the clutch doesn’t even click when pushing the a/c button.
I can see the compressor from inside the motorhome when I lift open the doghouse.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2022 at 5:29pm
Tomorrow will be cooler here(Liberty IA) heading out to Madison WI, will be there a couple three days, will dive further into the ‘The Beast’ as we call it, when parked.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2022 at 7:40pm
What year chassis is this and what engine? The later fords ecm has to see engine is running before it allows the a/c compressor to.kick in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2022 at 8:38pm
1994 F53, 460 w/TBI
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2022 at 9:33pm
Ok older is simpler, do as Steve suggested and check voltage, if present with key on, engine off tap the clutch and see if it locks in, if so air gap is too much and remove shim. First check fuse box there will be a fuse for the a/c, make sure it’s good.
This page was generated in 0.951 seconds.
