Ford Edge power windows? |
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10802 |
![]() ![]() ![]() ![]() ![]() Posted: 11 hours 21 minutes ago at 11:01am |
My BIL has a Ford edge mid teens with power windows. None of the windows work, all of them stopped working at same time. Checked the harness, power to the switch. Switch checks OK. No movement on any window. It has a child lock out on windows. Could this have an interlock causing problem. Thanks, Tracy
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87930 |
the Drivers Door is the control panel.. You can run any of the 4 windows from there.. EAch door has ONE switch for that door only.. I think the "child switch" just lock out the back two windows.... If EVERYTHING craps out at the same time, its normally the drivers door panel or the power to it... Have seen the harness get pulled at the door panel and break a wire to two running into the door..... If its not a fuse, etc, i would look at the drivers door control panel, and the wire harness feeding it...
not your exact car, but this guy does a good job of explaining..
Got it fixed. Was a relay that was causing problem. Thanks, Tracy
