Ford "Auto"n On The Locking Hub ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Ford "Auto"n On The Locking Hub ??
    Posted: 17 Feb 2022 at 5:52pm
WHAT is the purpose of this "segment" on the hub IF it does NOTHING to get you going from a slick intersection ?? AngryAngry
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2022 at 6:33pm
'Auto' probably does what my WARN Lock-o-matic hubs did decades ago....
When the vehicle supplies MORE torque than the road does, the hubs ARE engaged,so you have 4WD. If you shift out of 4WD,then the front wheels are 'freewheeling'.
These hubs will give you the best MPG.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2022 at 6:41pm
Thanks Jay. According to my manual, the "Auto" should let the truck get through "minimal" traction situations in 4x4 without the hubs being in "LOCK" ConfusedConfused ??  My truck does just the opposite as what your Warn hubs did Big smile
klinemar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2022 at 8:28pm
A lot of Auto locking hubs were replaced with locking hubs as they didn't work.
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2022 at 9:08pm
I assume you are referring to your 05 F250? Do you have the 4wd switch on the dash or do you have a floor shifter to engage the 4WD? If you have the switch you can leave the hubs in Auto if the vacuum system is working right and engages the hubs. If the vacuum system fails to work properly then you can “Lock” the hubs in. If you have the floor shifter for 4WD then you have to lock the hubs in manually.
TDF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TDF Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2022 at 9:11pm
What vintage truck are we talking about? 99 or later superduty at least up to the 2010's Auto only means the hub will auto lock if you put the transfer case in 4wd. Whether in auto or lock, if the transfer case is in 2wd then there is zero power to the front axle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2022 at 6:09am
hmm 'auto' is a button or knob IN the cabin ? NOT on the HUB itself ?
THAT opens up a huge 'can of worms'.waay too much 'stuff' to go wrong.
The Lock-O-Matic  hubs were 100% mechanical selfcontained units.
Old Skool....real old skool... easy to use, built to last....
ONLY if I went  offroad , did I need to get out and 'lock' them.
great now I'm missing my Willy pickup, sniff,sniff....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2022 at 7:09am
My 99 F250 has Auto Hubs, requires a Vacuum Signal from a Solenoid on Right Inner Fender Pan that most have no clue drives them.  The valve corrupts or the plastics degrade and the vacuum signal never occurs, even the vacuum lines to the front spindles can be damaged and will not function.  These are not Brain Science or Rocket Surgery, just have to know how they function.
Still have a MANUAL 'ON' position if do Not engage with dash control.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2022 at 7:43am
sounds like they took a perfectly GREAT unit, made it complicated ..and it fails....sigh..
next you'll hear the hubs will have WIFI in them and the fancy dash computer will show when they're on or off....Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2022 at 7:49am
Tried to Simplify for the Simpletons that could not master Unlocking hubs for economy while ate up front Diffs and short shaft u-joints.  Have not had issues beyond having to manually 'ON' my own truck hubs when as stated the solenoid failed.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2022 at 10:35am
You haven't seen the push button 4wd yet?  Been out since dad's '92 Ford.  On half tons anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2022 at 12:51pm
FORD 1/2 tons have a knob on the dash for   2WD- AUTO- 4HI- 4LO ..... to engage the front end, they used a vacuum piston on the pumpkin to disconnect the drive shaft from the front axle from about 1997 to 2004 ... the AXLE half shafts were splined to the hubs and turned constantly.... In 2004 they moved the vacuum to the WHEEL ENDS so that when you went to 2WD and disconnected the drive shaft at the transfer case, it also disconnected the axle half shafts at the wheel ends so the AXLE and DRIVE shaft dont turn... little better gas mileage..... The "AUTO" allows the computer to turn the 4x4 on and off... The 4HI or 4LO locks it in until you switch back..
The heavier F250 - 350  used a different HUB and it could be LOCKED into position if the vaccum piston stopped working... as DAVE said above.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2022 at 5:39pm
Yes RED, That is what's on my buggy, the "dial " engagement Smile . I really miss the  center  "hump" lever that was on dad's  '78 and '97  model year Fords and my '95 model Dodge Ram Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2022 at 5:42pm
[QUOTE=jaybmiller]
[/QUOTE I have 2 positions on my "outboard " hubs, AUTO or LOCKED (I have to twist them one way or another) .
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2022 at 5:42pm
Last 4wd truck was my '86 F160 V8/stick..nice ride.
last 'push button' vehicle was the '64 Chrysler Saratoga, with the funky elctrogreen dash backlighting....
This page was generated in 0.208 seconds.
