Ford 750 backhoe |
Acguywill
Joined: 15 Jan 2024 Location: Vauxhall ab Can Points: 154 |
Topic: Ford 750 backhoePosted: 09 Nov 2025 at 8:04pm |
We have an old Ford backhoe with a 3 speed Clark powershift transmission that is having issues. When shifting into forwards it takes a few seconds to engage no matter which gear is selected. Put it into reverse and it works fine. Shift from reverse immediately to forwards it works normally but if I shift from reverse and hit the brakes and then into forward it takes a few seconds to engage again. I disconnected the dump control valve that disengages the transmission when hitting the brakes but that has made no difference. Oil level is good and it doesn't seem as if the transmission is slipping any as it pushes good. Any ideas?
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34474 |
Posted: Yesterday at 6:28am |
Seals internally are hardening and failing.
Acguywill
Posted: 14 hours 12 minutes ago at 8:47pm |
What's more likely, the forward clutch seals or the shuttle valve? I used it tonight to feed the cows and calves and it seems to be somewhat random. More like something sticking or blocked. I will have to do some research on this thing.
