Ford 750 backhoe |
Acguywill
Joined: 15 Jan 2024 Location: Vauxhall ab Can Points: 153 |
Topic: Ford 750 backhoePosted: 13 hours 25 minutes ago at 8:04pm |
We have an old Ford backhoe with a 3 speed Clark powershift transmission that is having issues. When shifting into forwards it takes a few seconds to engage no matter which gear is selected. Put it into reverse and it works fine. Shift from reverse immediately to forwards it works normally but if I shift from reverse and hit the brakes and then into forward it takes a few seconds to engage again. I disconnected the dump control valve that disengages the transmission when hitting the brakes but that has made no difference. Oil level is good and it doesn't seem as if the transmission is slipping any as it pushes good. Any ideas?
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34465 |
Posted: 3 hours 1 minutes ago at 6:28am |
Seals internally are hardening and failing.
