Ford 750 backhoe
Acguywill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acguywill Quote  Post ReplyReply Direct Link To This Post Topic: Ford 750 backhoe
    Posted: 2 hours 55 minutes ago at 8:04pm
We have an old Ford backhoe with a 3 speed Clark powershift transmission that is having issues. When shifting into forwards it takes a few seconds to engage no matter which gear is selected. Put it into reverse and it works fine. Shift from reverse immediately to forwards it works normally but if I shift from reverse and hit the brakes and then into forward it takes a few seconds to engage again. I disconnected the dump control valve that disengages the transmission when hitting the brakes but that has made no difference. Oil level is good and it doesn't seem as if the transmission is slipping any as it pushes good. Any ideas?
