FORD 4600 diesel injection pump |
Joined: 11 Sep 2009 Location: illinois Points: 90834 |
Topic: FORD 4600 diesel injection pumpPosted: 11 Jun 2019 at 1:10pm |
I bought a FORD 4600 2 wheel drive tractor with a 3.3 diesel motor for the son to use cutting grass at the farm. I "think" the oil levels were all OK are relatively new to start with. I went over today after he has run 10 hours to do a little mower work.. I pulled the motor dip stick and it was 2 quarts over full. I checked the radiator and the transmission and both are OK.. Steering was about 6 oz low... My first guess is fuel dilution, but I don't "smell" diesel in the oil.. Going to do a little more checking, but wondering about additional things to check.. Looked on You Tube and they talk about overhauling the pump with new O-rings as a "not to bad job".......... saw another post somewhere that said " look at return line inside the valve cover".... and "leaking injectors".........
Im not sure it is diesel and not sure about the original oil level, but if I DID gain 2 quarts over a period of 10 hours, that don't seem like a leaking injector... Any experience on where to look first ? Most COMMON problem ?
JoeM(GA)
Joined: 12 Sep 2009 Location: Cumming,GA Points: 4940 |
Posted: 11 Jun 2019 at 1:16pm |
Sounds more like your shaft seal on the power steering pump is leaking since the PS is low
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
Posted: 11 Jun 2019 at 1:28pm |
well , that is surely a possibility joe... but I drained 2 quarts out of the motor sump, and added 6 oz to the steering....... but I cant verify ORIGINAL levels so I will keep that in mind and MONITOR... just looking for good ideas on checks , if I missed something.
JoeM(GA)
Posted: 11 Jun 2019 at 2:14pm |
agreed. I was reading on my phone, didn't catch the 2 qts in 10, It is definitely of the age the the pump seal could have failed
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5204 |
Posted: 11 Jun 2019 at 5:18pm |
The DPA pumps do have shaft seal failure on occasion, and it puts fuel in the oil.
