Ford 4000
Dharless View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dharless Quote  Post ReplyReply Direct Link To This Post Topic: Ford 4000
    Posted: 30 Aug 2019 at 3:02pm
So I bought a Ford 4000 diesel engine 4 cylinder. The guy I bought if from said it was on a trencher. I've searched and searched and searched but still no luck with finding a Ford 4000 trencher. Anyone know anything about these. My goal is to turn it into a 13kw back up generator for my shop/home. It is definitely not a tractor set up because the clutch pedal is on the right side of the engine and sticks out at close to a 90 degree angle from the odd shaped transmission. Thanks
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2019 at 5:18pm
It was likely the power plant on a trencher not built by Ford. Ford sold a number of engines as power plants for others equipment.
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2019 at 9:22pm
4000 diesel would be the same as a 4000 tractor. My Hydra Mac skid loader has a 172 ci ford engine in it.
Pal of mine digs wells, several of his trenchers have ford engines in them. .
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2019 at 2:12pm
Were the 4000 diesels 4 cylinder in U.S. and Canada? Down here the British built versions were all 3 cylinder. Just curious.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2019 at 5:29pm
Ford 4000 diesel tractors 1964 and earlier are 4 cylinder engines that are basically a converted gas engine. The 1965 and later engines were a totally redesigned engine built as a HD diesel and the gas engines of the same time had a spark plug head for them on the same block. the 2000,3000 & 4000 were 3 cylinder and 5000 & 7000 were 4 cylinders.
Edited by PaulB - 03 Sep 2019 at 8:32am
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2019 at 10:07pm
I think PaulB meant the '65 and after were 3 cylinders.
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dharless Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2019 at 7:32am
Thanks for the information. I'll post some pictures later. I think what is throwing me off I'd the "hood" says ford 4000. I will have to start a project thread when I get going on turning it into a generator. Any input in 5hat project will be appreciated as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2019 at 10:17am
They very early "4000"s were the same tractor as the last of the 900 series.
Edited by DrAllis - 03 Sep 2019 at 10:17am
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2019 at 11:37am
Generator engines typically have a special or unique governor that is tuned to hold the rpms necessary for 60 cycle power output, i.e 1800 rpm, 3600 rpm depending on the generator.
