For the juicetricians,,,,,
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: For the juicetricians,,,,,
    Posted: 15 Feb 2022 at 2:29pm
 Need a little info from the Gurus on a part for the electric heater in the bathroom. I was lowering the "Low-High" setting on the heater when the dang knob came off in my hand,,,,I heard a "ping" somewhere on the tile floor and the heater stayed on but knob was just laying on top of the heater.
 The heater is a Two heat setting 750W and 1500watt that is only bout 6 months old but surely a china product.  Took the top cover off and the knob had screwed itself off the rheostat/Potentiometer housing and after screwing it back on (Left hand threads) there is a small piece that is pushed by the adjusting knob that closes the contacts to raise temp on heater. THAT piece is what I heard fly off in the distance,,,,,,somewhere,,,,!!!
I checked out Surplus Center and ebay and amazon but cannot find one similar.
 Wondering why a 3 position toggle switch "OFF-LOW-HI" wouldn't work instead of the rheostat type control,,,,?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2022 at 3:14pm
Is it under warm-ah-tee by any chance ??
OK, 'lever' switch won't work..
it has off,on one side, on the other side.. same as a '3-way' light switch for hallways.
draw 2 light bulbs and how you can ONLY connect one OR the other NOT both..
there's 'magic' in the MECHANICALLY design of the 'rotary' switch
Kansas99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kansas99 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2022 at 3:36pm
Ok Joe, I read your post then Jays and now I'm so confused I think I need to shut power off to my house tonight because I wired the basement with a 3 way switch, shi$ and I don't even know that the hell that thing in your picture is, well I understand that knob.LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2022 at 4:26pm
Joe, i dont really understand the "SWITCH"... Not sure if all it does is switch from 750w to 1500w ( two positions) or is it a rehostat / thermostat that sets the temp ?
You could install a double pole switch that was 750w on one side and 1500w on the other ( and maybe OFF in the center.... Or you could install a THERMOSTAT to vary the temp ?
This was on ZORO...
Edited by steve(ill) - 15 Feb 2022 at 4:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2022 at 5:53pm
post the name/make/model /number ? info of the heater
google might find xxx parts for it
if it only says 'off-low-high' then it's just switching 1 or 2 , 750w heaters on . It'll be preset for a max temp.
if it said '0.....10' and the knob smoothly rotates, it's an 'adjustable'  thermostat
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2022 at 6:49pm
LOLLOLLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2022 at 2:05am
Joe...if'n it was made in China...throws it away and go buy another...i don't wanna hear about your house burning down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2022 at 6:27am
IF ????
What isn't Made in China ???
If..IF.. that switch could be made here, it'd cost 3x more than the complete heater from China
BTW, DJ, you'll find that missing piece during the Easter Egg hunt...
