Footprint |
Topic: FootprintPosted: 24 Mar 2016 at 8:56pm |
16.9 x 28 tire has a 175 sq inch footprint and a 56 inch diameter. 15.5 x 38 tire is 180 sq inches and 61 inches in diameter. If you were traveling 3.5 MPH with the 28 inch tires, the same gear selection would have you traveling at 3.8 MPH with 38 inch rubber.
cwhit
Joined: 12 Sep 2009 Location: Sigel IL Points: 1014 |
Posted: 24 Mar 2016 at 5:30pm |
I don't remember the footprint # but when we used 16.9-28s we could pull in the 5500lbs class and spin out. When we put on the 15.5 38s, it would kill it.
patrickmull
Posted: 24 Mar 2016 at 2:00pm |
ground speed is most of it I can pull farther in the 4000 open than I can in the 4000 4 mph
allispuller
Posted: 24 Mar 2016 at 12:23pm |
Ground speed plays a big role in that with the same gear ratio a 13.6x38 will speed the tractor up so there for you are getting the bars to the ground faster
bradley6874
Joined: 05 Sep 2010 Location: salisbury md Points: 1349 |
Posted: 24 Mar 2016 at 11:58am |
Charlie the way I see it the shorter tire digs deeper so your climing of of a wide deep whole instad of a long narrow shallow whole with less taper.
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Posted: 24 Mar 2016 at 9:27am |
OK, some places limit tire footprint (Say 170 sq inches)
A 13.6x38 is 168 sq in while a 14.9x28 is 170 sq in. Seemly equal but why does the 38 seem to pull better?
Charlie
