Followup on WD WD45 pistons |
Michael Crowe
Joined: 11 Sep 2009 Location: Kansas City Points: 1748 |
Topic: Followup on WD WD45 pistonsPosted: 20 Nov 2015 at 8:38pm |
I finally had a chance to get to the farm and take some pictures. I will post each engine kit or set of pistons in a separate post to minimize confusion.
This is a set of 4 WD 6.6:1 ratio pistons. ![]() ![]() Edited by Michael Crowe - 24 Jan 2018 at 3:11pm |
The 15th Annual Exclusive AC Swap Meet will be held in Boonville, MO, March 6-7, 2026. See the club website for details: http://www.moacclub.com/
Michael Crowe
Posted: 20 Nov 2015 at 8:43pm |
This is a set of 6.45:1 compression pistons for a WD45.
![]() ![]() ![]() Edited by Michael Crowe - 24 Jan 2018 at 3:15pm |
Michael Crowe
Posted: 20 Nov 2015 at 8:45pm |
This is a 5.5:1 compression piston for a WD.
I only have one of these; not sure where I got it. ![]() ![]() Edited by Michael Crowe - 24 Jan 2018 at 3:17pm |
Michael Crowe
Posted: 20 Nov 2015 at 8:47pm |
This is an Engine Kit, 257454, this is a 5.7:1 compression ratio for a WD engine.
![]() ![]() ![]() ![]() Edited by Michael Crowe - 24 Jan 2018 at 3:23pm |
Michael Crowe
Posted: 20 Nov 2015 at 8:49pm |
This is an Engine Kit for a WD45 with 6.45:1 compression ratio pistions.
![]() ![]() ![]() ![]() Edited by Michael Crowe - 24 Jan 2018 at 3:27pm |
Michael Crowe
Posted: 20 Nov 2015 at 8:51pm |
This is an Engine Kit for a WD45 with 7.25:1 compression pistons.
![]() ![]() ![]() Edited by Michael Crowe - 24 Jan 2018 at 3:30pm |
Michael Crowe
Posted: 20 Nov 2015 at 9:00pm |
I have 3 WD45 6.45:1 engine kits and 1 WD 5.7:1 Engine Kit that I will sell. I also have 4 NOS 6.6:1 compression WD Pistons. All these kits and miscellaneous pistons are NOS. I also have a 4 NORS Sleeve Kits for a WD Distillate Engine.
Sorry to take so long fixing the above posts due to the Photobucket debacle. Please email or call me if you are interested. I rarely check PM's. mcrowefarm@gmail.com or 816 898 7277. Edited by Michael Crowe - 24 Jan 2018 at 3:35pm |
Dmpaul89
Joined: 06 Mar 2013 Location: Edwardsville,IL Points: 1689 |
Posted: 20 Nov 2015 at 9:11pm |
Im interested In a 7.25 kit ill contact tomorrow.
Brian G. NY
Posted: 20 Nov 2015 at 9:12pm |
Great Information and pictures! I make a motion that this be made a permanent post like Brian Ahart's post on wheel weights.
Posted: 21 Nov 2015 at 6:11am |
Wonderful. So, the WD-45 LPG piston really is the same piston/piston bowl as a D-17 gas engine, whereas the WD-45 gas is the cereal bowl design.
TedBuiskerN.IL.
Joined: 11 Sep 2009 Location: Davis, IL. Points: 1961 |
Posted: 21 Nov 2015 at 7:44am |
I would say the 7.25 : 1 WD45 kit would be a later kit, since they are the D17 design.
The parts book shows the 5.0:1 WD piston the same part number as the 7.25:1 WD45, and I would assume, since it is a WD piston design, would be a flat top piston. Great post.
Edited by TedBuiskerN.IL. - 21 Nov 2015 at 8:28am |
Michael Crowe
Posted: 21 Nov 2015 at 9:40am |
Just to add a bit of light on the 7.25:1 lpg piston, when I rebuilt my 1953 WD45 Distillate it had the 5.0:1 compression ratio pistons, part number 223507. The pictures I took were not the best but my recollection is that they were dished; could be flat tops, but definitely not the recessed bowl like the lpg piston.
The parts books I have shows the 5.0:1 piston, 223507 the same as the 7.2:1 compression piston. I don't know if it is a typo, or if the 7.25:1 was a separate piston than the 223507. My suspicion is that it is not a typo, because the parts books shows the 223507 to also be a WD45 piston, but it does not show the lpg piston to also be a WD piston or even a 226 power unit piston. Another interesting sidenote, when I bought my rebuild kit from ACGO to rebuild my WD45 Distillate, it came with the lpg pistons. |
JPG AUSTRALIA
Posted: 21 Nov 2015 at 5:54pm |
WC and WD kero /distallate engines have the cereal bowl pistons,i dont know what their part number is but i,d say if they went on a wd 45 crank you would get 7.25 compression. They sit down a fair way in the 201 cylinder.
Don(MO)
Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Posted: 23 Nov 2015 at 12:25pm |
Brian is right this post needs to get put in the new spot for all to find latter on down the road.
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 23 Nov 2015 at 6:31pm |
Wink I am a Russian Bot |
Michael Crowe
Posted: 24 Jan 2018 at 3:56pm |
I just reposted all these pictures due to the photobucket mess.
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5179 |
Posted: 24 Jan 2018 at 5:20pm |
One of my D-17's had the (7.25/1) 229717 pistons, the same as the photo above. Reliant's 7.25/1 pistons are virtually identical.
Auntwayne
Joined: 23 Apr 2011 Location: Edwardsville Il Points: 1589 |
Posted: 24 Jan 2018 at 9:53pm |
Thanks Michael, I missed it last time.
Dad always said," If you have one boy, you have a man. If you have two boys, you have two boys". "ALLIS EXPRESS"
Don(MO)
Posted: 25 Jan 2018 at 11:38pm |
Thanks for bringing the pic's back on here.
