flywheel weights wd 45 weight? |
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3914 |
![]() ![]() ![]() ![]() ![]() Posted: 09 Dec 2024 at 2:22pm |
weighed some flywheels today 49 wd 60# 37 wc 65# d17 series 4 59# , what does the wd45 weight ? the wc does not have a ring gear but once its machined for a ring gear it will still weight more than the wd flywheel because its hollow under the disc face . how much does the wd 45 flywheel weight ? i have been told they are heavyer. how much weight is to much weight on the crank for my puller project ? has any one welded the crank side of the wheel to gain a few more pounds dont have 45 one to wieght
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21905 |
I used to make a donut out of 5/8" thick steel bolted to the front of the flywheel. About 12 lbs extra weight.
what about putting some wieght on the dampner pulley also ?
Unless it is as big of diameter as the flywheel, it won't do much. Might eventually break the snout off the crank.
i guess that s why i have never seen any aftermarket stuff out in the auto world on that end of the crank , i probley should just put a single front pulley on this engine and save the double pulley for power steering on my wd
