Flywheel on WD, what would you do? (Pics)
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Topic: Flywheel on WD, what would you do? (Pics)
    Posted: 25 Sep 2010 at 9:02pm
Well, the transmission tower is back together again, that was a good lesson on what not to do, almost glad that happened because I got a little education on detent springs, ball, and everthing else in that dang tower. Works good now though, whew!
Anyways, we pulled the engine tonight, and I have a new replacement pressure plate and clutch plate from Tony to put on. We did notice one possible problem though, The inside of the flywheel has cracks going outward. The cracks are no longer than 1", and there are quite a few. See pictures.....
My question is this, I am not sure when they started, or how really, but do you think there is a good possibilty this will continue to get worse? Should I change it out, or are they all like this? The tractor won't be seeing much work as long as I own it, but I do plan on putting the mounted picker on it, and thats all it will be used for.
What would you do?
Thanks again guys! Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2010 at 9:10pm
The cracks are heat cracks caused from the clutch slipping. It don't look good to me but I'm no expert. My clutch slipped a couple times on me years ago so I pulled the engine and found bad cracks all around. I got a replacement. The replacement had maybe 6 very small cracks and has worked fine for 15 years. The original in my 35 WC wasn't looking cracked at all till I made a clean-up cut on it in the lathe.
Edited by CTuckerNWIL - 25 Sep 2010 at 9:13pm
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2010 at 9:18pm
I'm like Charlie, no expert, but I would replace it, I can't see it getting anything but worse. That's a spinning mass, subject to centrifugal forces
I am still confident of this;
Wait for the Lord;
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2010 at 9:21pm
Normal heat cracks. I wouldn't worry about them.
If it makes you sleep better at night take it to a machine shop or NAPA to be resurfaced. The cracks are not usually very deep.
Note, Not long after you put in a brand new flywheel it will have cracks in it. I have never seen one from cars, trucks or tractors without cracks in them.
Edited by Jeff Z. NY - 25 Sep 2010 at 9:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2010 at 9:32pm
Wow Jeff, thats kind of what I like to hear! I wondered if all of them were like that,
I noticed they were not deep, and that flange widens out alot outward.
Any other opinions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2010 at 9:44pm
Run it. You didn't even know it was cracked until you took it apart.
Bertman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bertman Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2010 at 10:08pm
take it and have it sufaced its FINE
dannyraddatz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2010 at 6:31am
Don,
I can't tell for sure but it may be a good time to do a front and rear main seal. I bought mine from a AGCO dealer and it was 10% more that NAPA but turned out perfect!
Danny
Danny Raddatz
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2010 at 6:54am
I didn't look that close at the engine picture till Danny mentioned the seals but it looks like you have an exhaust leak between the head and the manifold. I had leaks there and up front and didn't think much about it cause I didn't use the tractor much. When I got around to replacing the gasket it only lasted a couple months  cause the manifold and head were both burned back. I pulled the head, resurfaced it a and cleaned up the manifold.
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2010 at 7:36am
definately take it to be resurfaced at least. it will make the clutch disc last alot longer if it has a true surface to ride against. don't be surprised if it may have been cut before and be too thin. the cracks are from the clutch slipping, probably starting out pulling big loads. if you don't cut it, the clutch may chatter and you will kick yourself.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2010 at 7:58am
Don, The flywheel needs to be turned and the top of the step needs to get it so the difference between the two are back in specifications, That is based on the look of the clutch disc. Can you post a pic of the p plate so I can see it too. I'd put a new ring gear on there too. Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2010 at 9:26am
Don here is the P plate and clutch plate, I have new replacements I plan on putting in.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2010 at 9:35am
Have it refaced, ground to a flat surface. If it was nine I would be using a button clutch instead of fiber. But to each his own. And as it is a recessed clutch both mounting surface and friction area need to be cut same depth .
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2010 at 9:40am
Don(MI), I believe Don(MO) was referring to the pressure plate side of the cover assembly...that's the part he was wanting to look at to see how cracked up it was,if at all. The flywheel might have gotten hot and cracked previously,before this clutch was installed,with the one before it from slipping. As for the flywheel...to each his own. Once resurfaced it'll probably be just fine,however,with thousands of WD/WD45's out there,I would opt for a good used one that wasn't cracked.   Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2010 at 9:47am
Thanks Coke, That's what I was trying to say about the flywheel.
Don, I think you need to get the flywheel cut because it's not true across the friction part of flywheel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2010 at 9:49am
Rick, It's about time you got on here a straited us out. LOL
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2010 at 1:44pm
Yes, I thought about that after I put those on here, I was in a hurry to take off and just got back now. Here are the other pictures of the back side of the pressure plate.
Edited by Don(MI) - 26 Sep 2010 at 1:45pm
powertech84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2010 at 1:49pm
Cracks in the flywheel are very common and don't hurt anything. I see it all the time. Have the flywheel resurfaced and put it back together.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2010 at 2:25pm
Don(MI), Please e-mail me direct at rickinmo@socket.net ,so I can chat with you a moment. It'll be worth your time.  Rick
Mike(SEIN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike(SEIN) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2010 at 3:55pm
while you're in there I'd put a new seal in the front of the torque tube, just so you don't have to pull that engine later.Don't ask me how I know.
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2010 at 9:04pm
resurface the f/wheel.the pressure plate is toast.fingers are worn and many blue areas.also rep.the throw out bearing and the clutch disc.you will sleeo better when you do
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2010 at 8:43am
Don, I just got my tractor put back together.  I'd had two of the 1/2" bolts that hold the flywheel onto the crankshaft come out and the other two were broke off.  Make sure to use some loctite when reassembling.  My mechanic said he'd never seen that happen before.  FYI.
Brian F(IL)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2010 at 3:32pm
Personally, there wouldn't be anyway I would re-install that flywheel without at least having it resurfaced and miked! Putting a new clutch on a flywheel like that is a waste of your time and money for that matter. Cracks are one thing, but look at all the hotspots gall & chatter marks that are in that flywheel! That thing is toast at present. You'll ruin the new disc and put hot spots in the new PP again because of it slipping, and you'll have four pieces of junk. The old junk clutch & PP, and the new junk clutch & PP.
Its your Tractor, but if you do right the first time, you won't be back in there to do that particular job again.....
Steve@B&B
CJohnS MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2010 at 3:43pm
I have pulled down engines for other repairs that looked worse & closed my eyes and put it all back together with no issues.
If I'm putting in a new disc, then I AM putting in a new throw-out bearing AND pilot bearing/bushing.
That flywheel and pressure plate don't bother me. If the spring towers were uneven, or the fingers twisted or flatted off on the pressure plate, or the flywheel obviously dished - THAT would bother me.
I got a piece of paper right here with Grant's face on says that over half the "un-restored" tractors out there - not just ACs - look that way or worse. And the clutches work fine.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2010 at 3:48pm
As for pilot bearing and throw out bearing. Recall how much bother it was to get them exposed, that you have to do when they give up. Seems like cheap labor saving to do them now.
Gerald J.
