Fluttering Ammeter |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7640 |
Topic: Fluttering AmmeterPosted: 30 Apr 2020 at 8:50pm |
I got the D21 out of the shop and ready to put it to work. When I bought the tractor, the needle on the ammeter would flutter back and forth in the charge zone. I rebuilt the alternator and put a new voltage regulator on during the winter, but I find it is still doing it. The wiring is not the greatest, so that would be my guess. Are there any thoughts on what can cause this? I have a video of it, but I cannot upload it here, unless someone knows how. If you didn't see my pictures on facebook, here are a few. Who doesn't love looking at d21s??? Spent a lot of money, fixed a lot of things, doesn't look noticeably better, but runs sweet! Looking forward to getting out in the field next week! ![]() ![]() |
Joe(TX)
Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Posted: 30 Apr 2020 at 9:32pm |
Was it at low rpm? A bad rectifier or diode in the alternator would cause that.
DSeries4
Posted: 30 Apr 2020 at 9:47pm |
Any RPM. Low, high and everything in between.
JoeO(C-MO)
Joined: 12 Oct 2009 Location: 3rd Rock > Su Points: 132 |
Posted: 30 Apr 2020 at 10:16pm |
New brushes and cleaning the slip rings
D10 III, D15 II 3 pt, D15 II SC, 170 Gas w/shuttle, 175 Diesel UI ROPS, 185 w ROPS. AC 653 w/6 way blade, ROPS
AC 615 Ind. WD45 running/Parts. |
Brian G. NY
Posted: 01 May 2020 at 10:51am |
Try another ammeter......some of them do not work well under vibration.
I had the problem on a WD and another ammeter worked fine.
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6126 |
Posted: 01 May 2020 at 2:05pm |
Yep, could be anywhere from alternator right up to the point where the ammeter charge wiring gets back to the battery. Other guys would know better... is charge current routed through the keyswitch? It could be as simple as a wire that has wicked in moisture, and become corroded internally to the point where it's starting to lose continuity. I would NOT throw parts at it yet... I'd make a jumper wire, and bypass each span of the wiring FIRST,and see if any particular jump clears it... if it does, you've isolated the problem.
BigGuy1000
Posted: 02 May 2020 at 3:15pm |
As long as it averages (to your eye) in the + side or charge zone, this is OK and normal on some ACs, our 170 and 175D have done this for 50 years and have always kept the charge OK as long as the battery and alternator are good! If it flutters between 0 and 10 amps, the average is then 5 amps, for instance, or between 0 and 20 then average is 10.
It is possible to get an ammeter with heavy "damping" so that it does not flutter like this, but there is no operational advantage to doing this, and most older ACs do not have this. |
BigGuy1000
Posted: 02 May 2020 at 6:01pm |
This is because the older Delco alternators usually found on old ACs have an "on-off" method of regulation of the charge current, whereas some other kinds of alternators have an inbetween on and off method of control. Either method is fine as long as the battery, wiring, and the alternator are OK!
DSeries4
Posted: 02 May 2020 at 8:49pm |
It is not discharging, but it does swing pretty far over on the charge side. Original AC ammeter shows +40 as the maximum. The needle swings between 0 and 35 very frequently. I just don't want the batteries to over charge.
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34641 |
Posted: 02 May 2020 at 10:00pm |
If the Ammeter needle is fluttering, it is the points in the regulator that momentarily "stick" and then "break open" that causes it. I changed the regulator to electronic regulator and it ran smooth. If you see the lights flickering and the ammeter swinging, then the points are getting burnt. and when they stick "on" and don't release, then you will cook the batteries. The ammeter shouldn't really flutter when everything is in perfect shape. jmo.
DSeries4
Posted: 03 May 2020 at 9:52pm |
The voltage regulator is a brand new electronic one - no points in it. "The ammeter shouldn't really flutter when everything is in perfect shape. jmo." I know. Rebuilt alternator and brand new electronic voltage regulator. Aside from wiring, could it be anything else?
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25276 |
Posted: 04 May 2020 at 6:08am |
I'd remove ammeter from tractor and 'bench test' it. wire it up to battery and a few 1157 light bulbs. 1157s draw about 2 amps each ,so 5 of them in parallel should move the needle to about '10' amps. At a constant draw, needle should be steady. If it is steady , the ammeter is OK If you 'pulse' the power, on -off at say 1 second intervals, the needle should jumpt to 10 and stay there, NOT 'jump around'. If it is steady , the ammeter is OK So... if the ammeter works fine 'on the bench', the problem is on the tractor. I suspect the wiring, if original though alternator or egulator could be faulty, even if new. 'faulty' doesn't mean 100% bad. ? does it flutter when headlights are on ?? ? any other 'loads' like radio,aux lights, etc ?? ? have you tried another battery ?? |
