Fluid Question |
Pa'sOldA/C ![]() Silver Level ![]() ![]() Joined: 21 Oct 2010 Location: missouri Points: 134 |
![]() ![]() ![]() ![]() ![]() Posted: 27 Nov 2010 at 9:58pm |
I have been told I need to use Hytran in my D-19 Hyd. Then I was told no use Standard Hyd. Oil and then I was told Use 30 wieght Non-Det. I'm not sure what was used in it before I bought it. My D-17 I new what to use but the D-19 I have been told all kinds of things. So I figure I would get a straight answer from the forum.
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Most all these old tractors used a straight weight Non detergent oil when new cause that is what they had. The hytran fluids are well suited for transmission, differential and hydraulics. I have used hytran in my WD45 for years. It is in everything but the engine and the final drives.
darrel in ND ![]() Orange Level ![]() ![]() Joined: 22 Nov 2009 Location: Hebron, ND Points: 8713 |
I've used CaseIH hytran in mine for about 15 years
HyTran has additives that capture moisture and turn to jelly keeping water from being circulated.
