Floor model air conditioner |
bobkyllo
Joined: 14 Sep 2009 Location: minnesota Points: 1569 |
Topic: Floor model air conditionerPosted: 25 Jun 2024 at 9:44pm |
I have a floor model ac machine I bought to put in my shop office in town. But seeing as our town has some new little s**t head want to be thugs I refuse to pipe the hot air through the window. Seems like a lot of extra work everyday.
My thought is to drill a hole through my wall and pipe the hot air out that way. That way my window will stay secure. So I thought about one of those dryer vents with the flaps that close when my in use. My question to you guys is this. I believe right now the ac machine breaths through a 5 inch or 6 inch tube. Will I hurt anything if I neck it down to something more common like 4 inch. |
Codger
Posted: 25 Jun 2024 at 10:02pm |
I wouldn't "neck" it down. By doing so you increase static pressure and exponentially increase resistance to free airflow. The hot airflow is from your condenser coil and the more air across it the better and more efficient it will work.
That's All Folks!
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6124 |
Posted: 25 Jun 2024 at 11:27pm |
The biggest resistance to your portable AC unit's venting, is the flexible plastic hose. Necking it down for the short distance of that vent isn't the end of the world, but if you're mounting it in a semi-permanent setup, you can compensate by going to a hard tube (smooth wall) rather than the flex plastic, and you'll have no worries about the vent hood. You could also go looking for a larger vent hood- aside from dryers, they make larger 6,7,8,9,10" hoods for kitchen stove and similar applications... or if you know a good sheet metal guy, he can make up one. I made a vent hood for a buddy, with a gravity flap out of stainless many years ago, nothing really fancy... but durable and seals well... he takes the blower hose off in winter and slips in a plug made of three circles of 2" ping foamular 250... then rubber-bands a plastic bag over it.
bobkyllo
Posted: 26 Jun 2024 at 9:55am |
I'll have to look for a larger vent cap. The distance this will run won't be over 4 feet. It will sit in the corner and stay there until winter at which time I'll plug the hole to keep the cold out.
What can I use for duct work? It comes with a really stiff and rigid flexible pipe. Can I use something more flexible like they would use in heating ducts |
Codger
Posted: 26 Jun 2024 at 10:15am |
I would use 8" insulated round duct such as used in home construction. Very flexible and depending on cosmetics needs is easy to wrap with cloth. Use insulated duct to keep the radiant heat out of the space.
That's All Folks!
Joined: 11 Sep 2009 Location: illinois Points: 90801 |
Posted: 26 Jun 2024 at 4:49pm |
area is PIE x Radius xx 2........ so 6 inch diameter is 3 inch raduis or 9-PIE surface area.... 4 inch is 2 radius or 4-PIE surface area so less than HALF the discharge.... You should go BIGGER... like 8 inch and SHORTEST tube as possible.
BuckSkin
Joined: 12 Sep 2019 Location: Poor Farm Points: 1165 |
Posted: 05 Jul 2024 at 5:27am |
Just curious; why the floor unit instead of a window unit ?
captaindana
Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2609 |
Posted: 06 Jul 2024 at 4:33am |
To keep the thugs out I believe?
Blue Skies and Tail Winds
Dana |
