Flip Forward Seat for 100 series
pdh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pdh Quote  Post ReplyReply Direct Link To This Post Topic: Flip Forward Seat for 100 series
    Posted: 12 Aug 2024 at 11:55am
Have a new to me open station 200 that will earn a living on a grain auger so will sit outside all fall.  Needs a new seat anyway - and would like to replace with one which will "flip forward" on to the steering wheel so I can keep the rain and snow off.  Anything out there to accomplish this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2024 at 1:20pm
Yours must be the later model with the black seat suspension???   If you get the whole thing (orange) from a 190-190XT or early 200 you will have a different track and the seat will tilt forward.
pdh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pdh Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2024 at 3:28pm
Should have been more precise.  1973 serial 5### was factory cab - cab removed by prior owner.  The seat suspension is orange now  - but I sure don't see a hinge?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2024 at 3:51pm
BUT, if he used the cab seat suspension, he's repainted it and it doesn't have a tilt feature. Does any of the seat suspension go down and attach to the platform ?? I'd say no.
pdh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pdh Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2024 at 9:56pm
Correct Doc.  Suspension attaches to front of fuel tank only - it does not extend to platform.  I will look around for the type of suspension you suggest.  Much obliged.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2024 at 9:43pm
A piece of 3/8" ID steel tube the width of seat base the cushion fastens to cut into 3 pieces and a piece of 3/8" rod 1" longer than the total tube you can make your seat tilt. I've done it on a late 185 and a 200. They do the same fall auger work you're doing.
 IF you know of an AC 100 series with the deluxe seat to go look at. Just copy how it tilts.
 I'm several hundred miles away from mine this week or I'd try to get you pictures.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2024 at 11:40pm
I looked at how my AC 180 deluxe seat hinged and did the same to the 185 & 200.
 They seem to work fine.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2024 at 1:10pm
Jim Nevels has your seat, he is not able to post on here,so I will leave his phone number. 660-527-3514 or 3524
pdh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pdh Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2024 at 11:58am
Thanks for the lead.
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2024 at 1:01pm
I have a complete seat assembly off a 190 minus the seat I'd sell in east central iowa if you're interested.
pdh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pdh Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2024 at 8:31am
Thanks - but I bought one already.
This page was generated in 0.058 seconds.
