Flat Spotted tires
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Topic: Flat Spotted tires
    Posted: 01 Apr 2012 at 7:08pm
Is there any old trick to getting the flat spots out of tires that have been sitting for quite a while?  The tractor has duals so I was thinking of turning the duals 180 so the flat spots don' line up anymore.  Can you over-inflate somewhat and hope they take shape again?
It's not in the book at the moment for a new set of tires.  I'm sure it won't be an issue once its in the field, just getting there sure will be a wild ride.
ACscott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACscott Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2012 at 7:35pm
I think with use they will start to take shape again, myself I wouldn't over inflate them but could be wrong.
Edited by ACscott - 01 Apr 2012 at 7:35pm
acd21man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2012 at 8:05pm
like when tractors sit  or in the cold ? a flat spot from siting. just drive it it will come out . always has for me, but i might not have explained it right lol
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2012 at 8:24pm
When I drove Terragators for a living the first ten minutes of the morning ride was kinda yummpy until the flat spots came out from sitting over night.
Inflate your tires to the proper pressure and drive them, they will smooth out.
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2012 at 8:51pm
Unless they were sitting for years they should be fine after you get them rolling for awhile.
AGCO My Allis Gleaner Company
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2012 at 8:54pm
once you put them under load in the field for a while they will flex into shape again, I do fall tillage for my uncles with a 9620 john deere, same problem but it went back to normal in a couple rounds of digging
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2012 at 9:03pm
If it has set all winter you might try turning the flat to the top  and let it set a day or so.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2012 at 9:07pm
I guess I should have said its been sitting for around 10 years, with no movement in the last 5 or so.
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2012 at 7:36am
Unless the rubber has gotten really hard they should round out over time, or bring the tractor out to my place (north Texas) around August and we can plow up some of my red clay.
1944 Allis C
1960 Allis D-17 LP
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2012 at 8:47am
Thanks guys. I guess I'll bounce my way to the tractors new home and get it dirty again and hope for the best.
