FL145 Loader Steering Pump prime
dfrancis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfrancis Quote  Post ReplyReply Direct Link To This Post Topic: FL145 Loader Steering Pump prime
    Posted: 11 Aug 2020 at 11:03am
I replaced a Hydraulic line that went from the steering filter to top of the rear-end. The machine will not steer now. There is plenty of oil in the hydraulic  reservoir. If I break the line loose coming out of the filter there is no flow. It splattered a little and then quit. Seems like the pump needs to be primed. Looking for any advice.
NomoreJohnDeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2020 at 1:43pm
did you do anything to "un prime" it?
if you take the filter out or the inlet to the filter loose do you have flow?
HD3
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfrancis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2020 at 1:54pm
I took the filter off. There is no flow to the filter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2020 at 7:16pm
Can try adding 5-10 lbs REGULATED air pressure to the tank and at a little at a time to see if any suction leaks then start it to see if will pick prime back up.
