Fixing up my Allis B
Jay Tee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay Tee Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2025 at 7:51pm
Except one factory manual says to bend the cross arm to shorten the carburetor rod, while another manual from a different year says bend the cross arm to lengthen the carburetor rod - the typos get confusing some times.  Anyway - it's running and moving on its own now without any fuss.
Edited by Jay Tee - 03 Aug 2025 at 7:52pm
CA13414 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2025 at 8:16pm
Awesome job!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2025 at 1:01pm
All small engine need to have the carburetor rod just a bit too short.
 All the Large (201-226) engines need to have the rod just a bit too long.
This is the discrepancy you are seeing and not fully grasping.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2025 at 4:33pm
All small engine need to have the carburetor rod just a bit too short...
Well, I do believe that to be true, but I have two manuals that are indeed contradictory.
This first screen shot is from the I&T manual which is known to be unreliable; however, not everyone is aware of that.
This second screen shot is from another manual, possibly an official version?
I have been able to glean useful information from both manuals as sometimes one gives a more thorough explanation than the other.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2025 at 5:50pm
On the whole the I&T (BUT FIRST) manuals should be trashed as much of the information is very general and not as specific as really needed. When in doubt go with what the OEM engineers published.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay Tee Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2025 at 1:15pm
This is from the 1960 issue of the Allis Chalmers Shop Manual produced by Technical Publications Inc. and available in several places online.  You can see clearly it's for the B-C-CA-RC engine - not the WC-WD engine.  Also it says the carburetor connecting rod should be 1/32" longer than necessary.
This next one is from another AC shop manual - the provenance is unknown, but it does seem to originate with AC themselves - this is the correct instruction.  Confusing, no?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2025 at 1:28pm
that last sentence about having slight tension on the governor spring when the throttle lever is in the LO  IDLE positon .... i have fixed that by loosening the square set screw on the LEVER and sliding the throttle rod in or out  1/8 inch.... You would be suprised now much  effect, 1/16 inch will make in the carburetor rod or the throttle rod...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay Tee Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2025 at 7:19pm
You can say that again!  I assumed that the settings were copacetic since nothing looked *too* far out of adjustment. Little did I know that these adjustments are far more critical than they are on small single-cylinder engines as found on garden tractors and lawn mowers.  I've prudently kept my mitts out of the governor in my big Kubota (my other favorite orange tractor) because it just works and it's buried in the high pressure pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay Tee Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2025 at 7:26pm
Changed the watery oil in the transmission and dropped the pans on both final drives. Looks more like tar in there!
And cleaned up with new cork gaskets cut
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2025 at 9:41pm
original gear lube was not much better than tar.... and let it set for 60 years and it REALLY looks like tar.. I normally use 80-90 wt... some guys use heavier... some have tried the newer HY-Trans type oils... ( not me !!)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2025 at 6:35am
Jay Tee,
 Nice documentation on your work with the B! Good looking tractor that you have made many positive improvements in too. I will be watching the set up ( throttle linkage ) on our CA when we get to that point.
What plans do you have for the B? the sickle bar would work good for mowing ditches.
 Chris and Cheryl
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay Tee Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2025 at 7:47pm
Jay Tee,
 Chris and Cheryl
Actually we were looking for a sickle bar mower for the Kubota, but then this B came up on Marketplace for less that a three-point project mower.  We both kind of missed the old CA, so we brought this one home.  My plan is to get it and the mower that's on it into good enough shape for regular use. I'm planning to keep it in its working clothes, although my wife thinks it could really use a nice paint job (uff da).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay Tee Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2025 at 7:52pm
This goobered up steering arm made me sad.
I happened on a good one and immediately installed it once it got here.  Now I'm not so sad!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay Tee Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2025 at 8:02pm
I'm using 80W-90 in the final drive housings and UTF in the transmission itself.  Things in there looked pretty good once I flushed out all the water and goo with about $10 worth of diesel.  It runs reasonably quietly with the UTF - I will see how things go and may replace it with 80W-90 later.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Jay Tee Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2025 at 8:15pm
Small job - Installed the shutters, bent up a bit of 5/16" threaded rod, added a hardware store spring, a shutter crank I found online and a lot of grease. Next maybe fit the grille...
Edited by Jay Tee - 12 Aug 2025 at 8:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay Tee Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2025 at 9:25pm
Finally got some time to spend on the Allis B - so I worked on the wiring
Here's the harness being laid out
After laying it out I covered it with split loom and two layers of Scotch 33. I forgot that the wiring loom is run under a cover in the tool box, so the location here would have required a hole cut into that.  The regulator is now inside the tool box, using the same holes the previous installer had used to mount it to the outside.
Finally here's a start on wiring the generator
Post Options Post Options   Thanks (1) Thanks(1)   Quote Jay Tee Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2025 at 7:48pm
It's charging! I had to tap on the regulator to get it to start doing its thing, but it's doing its job mow.
This page was generated in 0.088 seconds.
