Fixing to split our D21
CALEBnOK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CALEBnOK Quote  Post ReplyReply Direct Link To This Post Topic: Fixing to split our D21
    Posted: 11 Oct 2018 at 12:04pm
I'm about to split her in two but was curious to see what other members have for splitting stands. I'm going to fabricate some this weekend.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2018 at 8:10am
Need some holes in frame rails about where primer pump is. The stand I borrowed had crossmember between rear wheels to put jack on to support engine while fastened to frame rails. Might remove front weights but I can't see how they would be enough to make it front heavy. Just use caution.
fastallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fastallis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2018 at 8:29am
What is the extra tank mounted under the platform for?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CALEBnOK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2018 at 8:46am
The hydrualics are seperate from the rearend. They did that to help solve the rearend failures. Ive seen several d21's around here with this done. I know the mechanic that did them in the 70's and he said they never had another failure after seperating the systems
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2018 at 9:13am
I'm too ignorant to understand why making the hydraulics separate from the driveline would "solve" rearend failures.  Did they go to 80/90 wt oil in the rearend ??   The type of oil used is/was the same as a 5020 John Deere and they didn't have any rearend problems.  The fact is the final drives and axle bearings were a bit undersized and if then the HP was increased, you had set the clock ticking for trouble down the road. And for all those who know so much, if the D-21 was adequate in final drive size, why then did they increase the size of everything in the 220 ???  Even the late D-21's had 3.25" wide bull gears instead of the older 2.75" wide gears.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CALEBnOK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2018 at 12:01pm
This tractor has 80-90 in the rear. It was this way when we bought it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CALEBnOK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2018 at 12:02pm
And i couldnt agree more that the d21 rearends were junk
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2018 at 12:19pm
Just my opinion, but, if the so called junk rear end D21 tractors were inspected right after the rear ends went out, the injector pumps were turned up, probably weighted down horribly and most likely low on oil, each machine has a limit, abuse them till they crap out , then they are junk- most of the time its poor operators that cause the problems
Post Options Post Options   Thanks (0) Thanks(0)   Quote CALEBnOK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2018 at 12:26pm
Doug the rear gears in a 210 220 rear end are literally twice as wide because of severe failures.
The allis dealer that did this conversion said nearly every tractor they sold had a rear end failure.
Im sure maintenance was key but you could take a johndeere like a 5020 and neglect it just as bad and never have a failure.
Mike Kroupa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2018 at 12:55pm
Also remember the 5010/20 had planetary final drives were the AC's did not. Nice looking tractor btw!!, Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2018 at 7:06pm
My point was the final drives on D-21's were borderline adequate at best. If the HP (and torque rise) were left stock and the tractor was not weighted down much above 13,000 lbs  (100 lbs per PTO HP) the later 3 1/4" wide gears probably held up decently.  But, I doubt that they would have ever met the reliability of a D-17 S3 or S4.  I think of the thousands of those models that spent thousands of hours pulling a 3 x 16's or 4 x 14's plow and NEVER EVER had a differential or final drive failure due to inadequate design or strength. It just didn't happen.  The mighty D-21 would have been better served as it was originally....non-turbo and 103 PTO HP.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2018 at 10:05pm
I agree with you 100%.I was referring to the fact that the planetary design distributes the torque load evenly to three contact points. A local,long time retired AC mechanic, talks about replacing the 821 fluid with GL5 gear lube in early 190 XT's. This was done to preserve the 2 pinion differential until improvements were installed. AC Engineers did an about face in their designing of the 7000 series rear end which proved to be almost bullet proof right out of the box. My 7080 has over 9500 hrs. and has been trouble free from the range box back. My thoughts, Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2018 at 10:40pm
Planetary designed final drives have their advantages and disadvantages.  They are less efficient in transmitting power thru them.  They are more compact in size and can easily have wet brakes incorporated into them. They can be rugged and long lived, but if they aren't BIG enough, they too will fail early. Same can be said for bull gear/bull pinion designs. If built BIG enough, they can be very reliable. They are more efficient in power loss thru them.  Older Cat Challengers are bull gear/bull pinion designed and I've never heard of one failing due to a design flaw. Many in California have 20,000 plus hrs on them.  If the D-21, even with the later 3.25" wide gears were problem free, why was that design dropped in favor of the replacement model 220 with the inner axle bearing relocated and final drive gears made much beefier ?? I think that says it all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2018 at 11:35pm
what ever you do....please make it STRONG! I don't wanna read an obituary!
RGW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RGW Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2018 at 6:26pm
I was very interested in this, as I am going to split my D21 this winter also, but it seemed to get off track quickly. I am going by the book, as I don’t want to drill holes in the frame to split it. I am going to remove the weights, front axle, support casting, and side rails. Then remove the engine and clutch with a cherry picker.
If anyone has any pointers, that would be great.
Thanks
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2018 at 6:47pm
Never had to split a D21, but if I did, I would just build a frame rail "clamp on" where the frame sat down in a "U" shaped pocket to cradle the frame, and bolts tight on top.  Since that isn't as good as bolting to the frame in two spots on each side, I would add some sort of tie off rod or bar, that runs from the bottom of my front splitting stand up to the front of the frame somewhere.  The stands I built are a two post design for the engine support, one vertical support on each side down to a 4" heavy wall square tube running horizontal under and perpendicular to the tractor with roller jacks on each side.  This really isn't meant to be a picture of the stand, but you can kind of see what I am talking about.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote CALEBnOK Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2018 at 8:57pm
Thats about how i planned on building mine.
I want to make them clamp tonthe frame rails but will be adjustable so i can split my 210 later on and split a 190
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2018 at 9:20pm
Orange,looks like you got the good out of that limiter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2018 at 10:50pm
Somebody did, actually that is the way we bought it, got a good deal, a few parts and now it is a good chore type tractor.  The previous owner used it on a big rototiller, death on TLs.
Still in use:
