Fixing to Bush Hog today
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Fixing to Bush Hog today
    Posted: 30 Aug 2025 at 9:57am
Time to sequester the renters cows, close a few gates and drop the remnant weeds scrub growth from this year.
Should be a good day.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2025 at 10:11am
I cleared out some old fence by the house early this morning ,, got 10 acres I live on , this was the first year of no livestock at all - gee wizz the sprouts are everywhere its so dry around here , a spark would create a big fire,,
Edited by DougG - 30 Aug 2025 at 11:05am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2025 at 1:11pm
Well so far TWO Flats same tire, so likely sprouting Locust Thorns INSIDE tire and sticking the tube.  Out of Tubes, called around and no one open that has any.  So am stuck for weekend.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2025 at 8:32pm
Got in a good bit of bush hogging Thursday and Friday. Pasture really grows up with no livestock on it but the old FMC SW72 behind the D15 II took care of it. Dad bought that mower in ‘59 and it is still doing a good job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2025 at 5:43am
Aired up the tubes I have here that I pulled out as flats, planned on going to supply shop and buy patches. Not so good as the stems were cut/cracked at the rim exposure line. So brush and weeds were building up to the inside of rim, in turns the stems become exposed on the wheel turning Out from tractor and allowing the detritus to push the stems over enough the cause leak. Tubes themselves were fine under soapy water spray.
Left message at tire shop to buy Fluid Fill stemmed tubes, I have already ordered two Premium Tubes with that style stem for home stock, metal threaded and use the retainer nut to outside of rim. Should I decide to later, can always ballast those buggers as well.
TR218 style stems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 34 minutes ago at 2:42am
Another slug in the mess, the Tubes, 90+% are Asian Made, rubber compounds from Asian suppliers tend to more Plastic than Rubber or any other elastomer for that matter.  Kind of like Rubber Tarp Straps that today will NOT Extend more than a inch or two unless buy the Premium brands at double to triple cost, is a reason are so cheap.
