Fitting an all crop 60 through small gates?
mountain_anderson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mountain_anderson Quote  Post ReplyReply Direct Link To This Post Topic: Fitting an all crop 60 through small gates?
    Posted: 13 Apr 2025 at 2:57pm
Hi all,
I found an all crop 60 from a farm for cheap, but i think my gates are too small to allow it to pass through. If I where to take off the grain table would it be able to pass? How wide is the wheel base on one of these?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2025 at 3:29pm
It would be more cost effective to widen the gates...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote mountain_anderson Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2025 at 3:42pm
The area I’d like a harvest on just recently got new wooden posts cemented into the ground, I wish I could, I’d rather not dig up the soil to replace them and get bigger gates
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2025 at 3:42pm
If you have a gate that is wide enough (but just barely), you'll have better luck backing the combine through it. The "Gate Post" pulley on the right is usually the first thing that gets destroyed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mountain_anderson Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2025 at 3:49pm
What pulley is the gate post pulley
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2025 at 5:21pm
Lower right as viewed from the back...Wink
You could make a poor man's gate, by removing 1 post, and adding a dummy post, staple the wire, make a loop of wire at the bottom and one at the top, to hold the dummy post...
Edited by DiyDave - 13 Apr 2025 at 5:30pm
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2025 at 6:47pm
If you want too just BECAUSE. You could take the combine apart into how ever small of pieces, so you could hand carry it through.  But if you might wish to harvest a crop in that field again make a gate that is wide enough for practical machinery. You can thank me when you are done harvesting and want to drive it out of the field to the shed.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2025 at 7:34pm
Backing through the gate:
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2025 at 8:03pm
Why not remove a section of fence? Drop the wire off a couple of the fence posts, pull one or two fence posts out, and drive over the wire laying on the ground, reinstall the posts, reattached the wire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2025 at 10:47pm
Hi all,
You have some measuring to do before anything. Then you will know what your options are. I'd saw off one side and make a new opening wide enough to pass through. Sounds like you don't want to do what's needed. New post would be a whole lot less trouble than disassembling combine.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2025 at 2:12am
Is the combine itself too wide or the combine when  hooked to the tractor too wide?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2025 at 6:34am
To answer your original question, no. Taking the header off won't narrow it up any on a model "60", as the straw walker area is just as wide as the cutterbar, if I remember right. Even if it made a difference, those headers aren't easy to remove, drag thru the gate (how ??) and that reinstall on the combine, and in the field would be even more difficult. If the combine itself can be worked thru the gate, fabricate an offset front drawbar on the tractor and push it thru.
