First time for this...
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Topic: First time for this...
    Posted: 09 May 2015 at 6:49pm
e
Edited by O.P.S. Heads - 21 May 2015 at 7:54pm
rowcropmafia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rowcropmafia Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2015 at 8:33pm
Good eye. I would have never thought of that happening
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2015 at 10:25pm
  Very interesting, thanks for the heads up.
mgburchard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mgburchard Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2015 at 5:46am
Who ground it so i can be sure to tell Pankey to never use them
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2015 at 10:51am
I've seen that also. Our lifters are larger diameter than the grinding wheel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2015 at 5:17pm
The truth is, I should have caught it by just looking at it. Time was short and this is the third cam (the first two were ground incorrectly) so I was in a bit too much of a hurry when I took it out of the box. Good thing I degreed it and found the issue vs. just slamming it home and starting the engine. Good thing also the issue was on the #1 intake lobe.
Moral of the story: don't go too fast and be sure to inspect every part prior to assembly. Don't assume everything is okay just because the vender shipped it to you.
Edited by O.P.S. Heads - 10 May 2015 at 5:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mgburchard Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2015 at 9:06am
Interesting moral of story I would have thought it would be Like three strikes your out
Edited by mgburchard - 11 May 2015 at 9:07am
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2015 at 7:42pm
No, it was one strike and you are out three different times. Three different vendors.
This page was generated in 0.119 seconds.
