First post my Wd puller project.
 Post Reply Post Reply Page  <123>
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2017 at 7:35am
the combine weights have a smaller rpm drop before it kicks in I believe
UglyAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote UglyAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2017 at 5:35pm
I found a cheap set of firestones that were wider and mounted them on a set of combine wheels.
The tires are 14.9 26s give me a little more bite.
Post Options Post Options   Thanks (0) Thanks(0)   Quote UglyAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2017 at 5:45pm
Here it is all painted up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote UglyAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2017 at 5:49pm
I wanted to continue to lighten up the tractor and the nose was still pretty heavy in the light classes.
I decided to run small 12" trailer wheels and tri ribs on the front
The bolt pattern was not the same so I had to open up the center hole and then drill new holes in the hubs and through bolt them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote UglyAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2017 at 5:56pm
I don't think it looks too bad.
mjbower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mjbower Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2017 at 7:20pm
Awesome good job bet it'll pull as cool as it looks
Post Options Post Options   Thanks (0) Thanks(0)   Quote UglyAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2017 at 5:30am
So the tractor runs great and I started this past season pretty happy. I was still moving a lot of things around on the tractor. I still couldn't quite get the front end light in 3500 so I started looking for a wc lightweight front pedistal
Here is what I found
I cut the 1/2 flange off the back. The lightweight front is 100lbs lighter.
Here it is mounted up
Post Options Post Options   Thanks (0) Thanks(0)   Quote UglyAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2017 at 5:49am
Here she is all loaded up for a pull.
Post Options Post Options   Thanks (0) Thanks(0)   Quote UglyAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2017 at 5:57am
So overall I was very happy with the progress this season. I am slowwly getting to where I want to be.
The motor runs great and have great power. I have most everything dialed in besides tires.... Need bigger tires.
My local track has a 15.5 38 limit and my competition all runs 13.6 or 15.5. I am always just a few feet behind them with my little 26s
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2017 at 2:26pm
Looks good and you didnt have to spend a fortune.
Post Options Post Options   Thanks (0) Thanks(0)   Quote UglyAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2017 at 4:16pm
Yeah it's been pretty cheap so far. Now I gotta buy tires and rims..... Going to cost more that the tractor lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2017 at 10:32pm
I like it! You  and the boys have done a lot of work to the tractor.
 Thanks for keeping us up to date.
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2017 at 5:18pm
it needs more weight on the nose' it will do a lot better' when it comes up like that you lose your drawbar height' your tires are working' if you keep the front down' it will take some motor then. because it will make the tires work more. also looks like the tires are a little soft' may need aired up a tad will also help keep your drawbar height' we run 20'' in' height.
Post Options Post Options   Thanks (0) Thanks(0)   Quote UglyAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2017 at 5:52pm
Thanks for the input. I definitely am still working on my weight placement. This winter I am building a better more adjustable hitch. I also need to start bumping up my psi as I go up in classes.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2017 at 3:58pm
Ideal weighting/balance is where you can just slide a sheet of paper under the front wheels as you spin out. Good luck hitting that every time !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote UglyAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2017 at 5:00pm
Thanks I definitely always lean towards a lighter front. Need to change my habit.
Questions on tires. I am going to buy a complete diesel rear ( transmission to finals). Looks to be a direct bolt on does that sound right?
I am still debating between 13.6 and 15.5 38s
My track I can run 15.5s but some other local tracks I have heard 13.6 for anything 4500lb and under. Opinions on that?
Edited by UglyAllis - 15 Nov 2017 at 5:01pm
ac720nut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac720nut Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2017 at 5:08am
Enjoyed your build, great to be able to include the boys
Post Options Post Options   Thanks (0) Thanks(0)   Quote UglyAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2017 at 6:57am
Thanks. We will be There it again soon once the bad weather sets in
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2017 at 7:52am
Depends on the rules where you pull and what classes/Divisions.
  NATPA DivII is 170 sq inches of tire or less on 4500# and down  which is 13.6 x38 (168) or 14.9 x 28 (170)
4500#-6500# max sq inch is 229.  I run 5000# + with the UC and have 16.9x34 (229)
Div III is 18.4x 38 max tire size
My club uses NATPA rules.
Edited by CAL(KS) - 16 Nov 2017 at 7:56am
Post Options Post Options   Thanks (0) Thanks(0)   Quote UglyAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2017 at 12:33pm
Thanks for the info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote UglyAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2017 at 12:38pm
My favorite picture from the summer.
My pit crew.
Post Options Post Options   Thanks (0) Thanks(0)   Quote UglyAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2017 at 8:43am
Well finally getting a little free time.
Motor is coming back out. Installing new crank seals and gaskets.
Post Options Post Options   Thanks (0) Thanks(0)   Quote UglyAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2017 at 4:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote UglyAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2017 at 6:05pm
Ok motors out and it's time to start stripping it down. The front cover is giving me fits.
What's the big bolt with the jam nut for?
Everything else is out and it won't budge.... Granted I didn't try real hard yet I didn't want to break anything so I wanted to do a little research first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote UglyAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2017 at 6:24pm
Front cover is off and started cleaning it up
Edited by UglyAllis - 25 Nov 2017 at 6:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote UglyAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2017 at 6:29pm
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2017 at 10:20pm
While you're practicing with your tires see if you can find some used ones at a tractor tire store or better yet see if you can find some on this forum, while they may be weather cracked some you're not taking a chance of buying the wrong tire and sinking a bunch of money in something that isn't going to work for you. Those two boys of yours look like they're having a blast. You'll win more with them than you will with the tractor I'm afraid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote UglyAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2017 at 10:47am
Thanks for the response. Progress has slowed up for a bit. I am working 6 days a week and having some family Heath issues so free time is a premium. I don't know if tires are going to happen this winter or not but it's ok either way. She will pull next summer regardless.
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2017 at 11:31am
Keep up the good work.and keep us posted! Go Orange!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote UglyAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2018 at 6:34pm
Well unfortunately I didn't get a lot of work done on the Allis this winter. I pulled the motor and re sealed most everything. Got it all back together and am not chaising some coolant leaks. I will be running the same tires as last year.   Should be fun either way
This page was generated in 0.088 seconds.
