First AC (Finally!) |
| Author | ||
Clayfoot
Joined: 23 Sep 2024 Location: Southern Ohio Points: 35 |
Topic: First AC (Finally!)Posted: 24 Sep 2024 at 8:33pm |
After pining over larger orange iron for a handful of years, and recently found myself with the means and need to add something with a 540 PTO to my duo of modified Power King tractors. Before I could buy an Ollie 550, I came across and checked out a narrow front, late '57 D14 serial number 8309. No gear jumping, no death wobble in the front, runs out nicely, had a newer brass radiator, everything works and even had the optional 3 point arms that locks into the snap coupler. I just couldn't get my mine off it, so "Vicki" joined the farm this past Sunday. I discovered that name etched into the homemade inner concrete rear wheel weights, along with the year 1959. I tuned the carb up some and she runs out even better, starts at the first press of the button with just a little throttle. I have a few things to do, like cutting off broken the stack retainer bolts on the manifold and drilling/tapping them, rebuilding the seat suspension and replacing the tach cable and fuel level gauge/seal (cable and gauge on the way), cutting off and knocking out a broken wheel rail stop, general straightening out of the fenders, and one day a total repaint (roughest part of the deal), but I have a few questions.
1. What lubricant goes in the front steering gear and how much? 2. I have a decent amount of play in the steering gear, is there an over center adjustment to tighten the lash? 3. I swear I read somewhere that a D15/160 governor spring can be swapped on the increase total engine speed and net a little more power, but I haven't been able to find were I read it. Is there any validity to this and would that upset the 149 at all? 4. This evening, I noticed what appeared to be oil on top of the front tires, but the booster above them was dry? I had drive it around this afternoon after the fluid servicing. Are there any expanded diagrams of the narrow front bolster floating around anywhere? My operator's manual isn't due for another week I haven't had it out and worked it yet, but I suspect I'll be living with the power director creep for while. I drained the fluid from the transmission, PD and hydraulic system and replaced them all with fresh J20C spec and I still get a fast creep with the PD in neutral. It's fast enough that it's just a bit slower than low range, but I can also stop it with the brakes. Edited by Clayfoot - 25 Sep 2024 at 7:15am |
| Sponsored Links | ||
Pat the Plumber CIL
Joined: 11 Sep 2009 Location: Springfield,Il Points: 4948 |
Posted: 25 Sep 2024 at 7:20am |
PD creep can be from tractor sitting for a while. PD is not completely covered in fluid when standing still. Metal plates between fiber plates in PD can rust ,corrode. Moisture can build up in system and causes plates to rust above fluid level. Back when these tractors were used everyday it wasn't as much of an issue. Change PD fluid at least once a year and use the PD . Go bale a few thousand small round bales with a roto baler and the creep will go away.
1964 D-17 SIV 3 Pt.WF,1964 D-15 Ser II 3pt.WF ,1960 D-17 SI NF,1956 WD 45 WF. |
Clayfoot
Posted: 25 Sep 2024 at 8:03am |
That's good to know. The PD will certainly get use as I have some very tight headlands on my tiny acreage, although, not as much of a workout as baling (hopefully one day with more acreage). Going to hook up a 6' finish mower next week and finish off the stalk stubs and weeds in my 8 corn rows (only about 100' long).
I'm now really confused on the oil on top of my front tires. I went out and scraped the buildup/dirt off the bottom of the booster cover and it was entirely dry, especially so above where the fluid starts on the tires. Doesn't appear to be any leaking from the steering shaft input. I also have about 1/4 turn on the steering wheel before the front tires start to turn with them pointed forward and sitting still. |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5164 |
Posted: 25 Sep 2024 at 11:32am |
As this is your first AC tractor, get yourself and operators manual for the specific model (D14) It will explain the many features that are unique to Allis Chalmers tractors. Enjoy your D14
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4768 |
Thanks(1)
Posted: 25 Sep 2024 at 1:00pm |
Come on Paul be a better READER and more encouraging. He said the book is ordered. He is all excited about a new toy. No need to be negative. Maybe you were thinking it was funny, if so add more ![]() ![]() ![]() ![]() . This place is dead enough, encourage new people. After we get them sucked in then we can pick on them.![]() ![]() ![]() |
Clayfoot
Posted: 25 Sep 2024 at 1:38pm |
ekjdm14
Joined: 20 Aug 2024 Location: Alsager UK Points: 987 |
Posted: 25 Sep 2024 at 2:07pm |
I dunno, really thought that was a fairly bright, rosy post for Paul ![]() *no disrespect meant at all
Clayfoot
Posted: 25 Sep 2024 at 6:30pm |
The manual arrived early! I'm waiting for the rain to pass or die down to retrieve it from the mailbox I should've added that I'm a mechanic and have been soaking up AC info for years in preparation for potentially owning a D series. I'm also not afraid to do some heavy modifications, although I do my level best to keep it tasteful. Some of the Power King purists are a little put off by my work I will be adding external hydraulics with integrated pressure relief valves to run some of my other hydraulic equipment I've put together, as well as my little Oliver 54 drill.
Edited by Clayfoot - 25 Sep 2024 at 8:54pm |
Clayfoot
Posted: 29 Sep 2024 at 10:29pm |
Fluids changed, new fuel level sender and seal installed, new seat shock bushings and adjustment bolt, hitch parts freed up, SMV bracket and location figured out, and I picked up a 7' IH 1300 today.
I'd share pictures, but my phone takes photos that are about 4 times too large for this forum. |
Joined: 11 Sep 2009 Location: illinois Points: 88637 |
Posted: 29 Sep 2024 at 11:19pm |
can you e-mail the photo to yourself, then resize ?
