Firing Uphill
ocharry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ocharry Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2020 at 11:58am
so Ranse,,,i been reading along here and yeah you could have missed but maybe not,,,,you say you got you a 6.5CM,,,,and you say the fox was sitting up hill looking at you at 100yrds,,,are you sure it was 100??,,,and you held in the middle of the target,,,vertically,,,,and you are using a 125 gr bullet
so if you got the rifle zeroed at 100yrds you should have smacked it no problem...my first question would be what bullet is in the shells you are using,,,foxes are really light skinned and if you are using a big game,,(deer) bullet it could have zipped right through that fox without expanding and he was dead and didnt know it until later,,,,you know run off and die later
i have a 6.5 CM too,,,i use it for coyotes,,and deer,,,i really like the cartridge and it is a pretty flat shooter,,,100yrds is a cake walk,,,,my zero is 45yrds,,,,and it is a hold on out to 200,,,,high and low from zero to zero is less than 1" and with that zero i only need 4.5 min of elevation to be on at 400yrds,,yep thats it for real,,so unless you hit a twig or something between you and the fox you more than likely just punched a small hole through that fox,,,,if the bullet hit a bone it would be a totally different story,,,,,of course it all comes down to,,, if you did your part and did the the squeeze the trigger and not the snap the trigger thing
i can tell you that varmint bullets and big game bullets work way different,,,,just,,,, IN MY OPINION,,,,,, there just aint enough stuff in a fox to make a deer bullet work like it is supposed to ,,,unless it hits a bone or something solid,,,,but thin skinned varmint bullets work great,,,wont work on a deer but foxes and coyotes,,,,oh yeah
anyway all that said you could have just missed ,,,it does happen the best of us,,,
just for shucks and grins what shell are you shooting??? curious minds want to know,,,if i had the particulars i could plug the info into a ballistic calculator and give you some data to play with
ocharry
modirt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote modirt Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2020 at 12:35pm
This is somewhat related........and may or may not apply to the situation.
Years ago, guy we knew shot at a rabbit in his garden with a dinky little .22......rabbit was uphill......shot missed. Later that day, news came on that police were investigating a murder........turns out that missed shot carried over the hill, over an Interstate highway and came to rest in the brain pan of a lady standing in her driveway. Dropped her graveyard dead where she was standing.
Somebody put 2 + 2 together and concluded it was guy's missed shot that killed her. He went to prison for manslaughter.
Since then, my pucker factor gets high when shooting up a hill or into a tree or anywhere I'm not entirely certain that shot isn't going to hit anything that matters when it comes down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2020 at 4:26pm
Exactly......rule #5....
The 5 Basic Principles of Gun Safety:
  • Treat every gun as if it were loaded.
  • Always point your gun in a safe direction.
  • Never point your gun at anything you don't intend to shoot.
  • Keep your finger off the trigger until your ready to shoot.
  • Be sure of your target and what's beyond.
Ranse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2020 at 7:02pm
If you like to know, I was using Winchester brand called Deer season XP. Cheap but I been shooting pretty good with them. I also like Hornady SST, they are 129gr I think. I don’t care as much for the Remington core lock. Those are the only ammo I’ve used in this gun. I don’t reload. BTW, the fox is still alive. I seen it again. I will get another chance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ocharry Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2020 at 9:49pm
Rance...I plugged in the ballistics for your winchester cartridge from winchester web sight...and I just guessed at your scope height center of bore to center of scope...put that in at 1.625....so they say muzzel vel is 2850...BC is .540....so with a 100 yrds zero..it said zero hold at 75... Hold over for 150 is about 1".... Hold over for 200 is just over 3".... You should verify that but its prolly pretty close....but you should be able to hold on a sitting fox out to 200...I would hold just under his chin at 200
I will tell you that my 140gr bullet has better down range ballistics and flys flatter than the 130 tipped game changer sierra bullet that I use for deer
That being a deer bullet that your cartridge has should kill a fox but dont expect great terminal performance.... Maybe not much expansion........ Unless you hit a bone
Good luck...I'm sure he will give you another shot...like Ted said...make sure you know what's behind your target....that bullet is going through for sure
Ocharry
Post Options Post Options   Thanks (0) Thanks(0)   Quote modirt Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 9:19am
I have grown curious about the 6.5 Creedmore. Seems to have gained popularity with the long distance shooters.......like the 1,000 yard guys. That is over half a mile away. Long distance shooting.....sounds like a fun hobby.
When my kid got out of the Marines......he started looking for a long distance weapon for fun and sport, and the Gunny he talked to convinced him to get a .308 Howa (same as Weatherby) with a bull barrel. Scope has since been upgraded to a long distance tactical. While his initial plan was to show up his cousins......who couldn't seem to hit the side of a barn.....from the inside.........he was hoping to drop a deer out to 800 yards.....just to say he had done it. I warned him that where he was hunting he would do as well with a 12 gauge and deer slugs.......but he wanted to try. So all the deer he has killed to date, average distance has been under 100 yards.
Anyway, in the sniper world, the .308 was and still is a popular category. That said, the ballistics of the .308 vs. the 6.5 Creedmore seem to be wildly different, yet those two seem to be the one's a lot of folks gravitate to.
If the 6.5 slings a 130 grain bullet, it ought to have stopping power up close.......not sure what happens out to 800 yards? .308 still has some smack out that far.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ocharry Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 10:29am
well modirt,,,the 308 is a really great round,,,but it goes subsonic around 8-900 yrds,,,where the 6.5CM goes subsonic around 14-1500 yrds,,,,with less recoil,,, so +2 for the creed
most guys shooting that far are using a 140-143gr bullet in the creed,,,,and 168-175gr in the 308,,,i just happen the have a pile of 6.5 140gr bullets from the old days of shooting the 264 win mag....i originally started looking for a 243,,,i wanted a 300yrd coyote gun,,,,then i found this 6.5 configuration and it just kept saying my name,,,,you know you want me kinda thing,,,lol,,,i really like this rifle and scope set up,,,so far it has 4 coyotes under its belt and i hope we put a deer in the freezer this fall,,,
i have both and just to be honest if i would have gotten the 6.5 first i prolly wouldnt own the 308,,,,i like it and it is a shooter,,,,but i got the creed in february for my birthday,,,,from me to me,,,lol,, and i tell ya it is pretty amazing,,,,i will say i reload for both,,,neither has ever had a factory round down the pipe,,,so right now knowing what i know if i had to pick i would take the 6.5,,,,,i have had it to 500yrds to date and it is kinda boring ,,,,ahahhahahahaa,,,,, i play with it from the drive way at 200 and i shoot at a 4" steel plate,,,,no problem,,pretty easy with this set up,,,if i miss it ,,,it is something i did,,,
800 for a deer shot is a pretty good poke,,,,big bean field shot for sure,,,,a lot can happen in that kind of distance,,,wound a coyote,,, not what i want to do,, BUT it might not bother me to much,,,wound a deer at that range and you may never find it,,,,and that wouldnt sit to well with me,,,
anyway if he already has the 308,,,then go for it,,,,the round is VERY capable at that range,,,PRACTICE,,PRACTICE,,,PRACTICE,,at that range so you know you can make a kill shot that far,,,the deer deserve that
my .02
ocharry
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 7:03pm
To be honest, I never heard of the 6.5 CM until I started gun shopping last year. I have a 30-06. I figured a 30-06 was about 150 yard gun in the hands of someone like me. With the size of my pasture fields I felt I need something capable of taking a coyote up to 400 yards. I wanted a.243, but after learning about the 6.5 CM and its long distance capabilities I wanted it. I figured if they were good at 1200 yards they should be great at 400. I’ve learned that’s not necessarily true. A 243 probably would have suited my needs just as well, maybe better. My axis is what savage likes to call a budget rifle. It has more plastic parts than most guns. It doesn’t work as smooth as my Rem 700, but probably shoots better.
festus51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus51 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 7:57pm
Yea I have a couple of Savage's  not always the smoothest action but they do shoot good.
We the unwilling Led by the unqualified Doing the impossible for the Ungrateful
klinemar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 9:20pm
I have a Savage Axis heavy barrel in 6.5 creedmoor. I like it a lot. Reminds me of my old Savage 243 that I sold. Both great shooters. The 6.5 is heavy to lug around so I have shooting sticks. The farthest shot on a critter was a sick raccoon at 250 yds and I held the crosshairs right on it. Anchored it. My rifle likes the 140 gr. Remington Core lok. I have shot the Winchester deer season 127 gr.but the 140 will shoot one ragged hole at 100 yes. I like the rifle as it is low recoil. I would reccomend it for anyone looking for an economical varmint/ deer rifle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote modirt Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 8:11am
My coyote / deer weapon is a Rem 700 BDL in 6mm Rem, I bought around 1979. Was a popular alternative to the .243 at the time. Factory ammo for that has all but dried up.
Lucky for me, have a friend who is an avid shooter and loves to reload.
My target practice guns are actually a pair of Beeman air rifles.
Kansas99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kansas99 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 11:32am
Nice to see there's some Savage fans on here.  I love collecting the model 99's, best lever action ever made in my opinion.  Have probably 60-70 of them running around the house somewhere.LOL
The Savage bolt actions are for the most part just accurate.  That floating bolt head and barrel nut just allow them to be mass produced and retain accuracy.
Here's a picture of the most accurate rifle I've ever owned.  Put it together myself, it's built on a Savage Axis action with a Brux barrel chambered in 6.8-284(yes I neck up 6.5-284) on a Dog Tracker stock from Sharp Shooter Supply and a Sightron 10-50X60 scope.  Great 1000 yard gun.  Now if I was just a better shot.Cry
Edited by Kansas99 - 11 May 2020 at 11:37am
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 11:47am
Ok Kansas 99 we don't need good looks unless your got fancy glass cases.Just not Wink good form to have them sitting all over the house anymore. LOL So being a lazy bum anymore got so plastic and SS steal are my favorites. I mostly pack a Heart Ruger 22/77 in plastic SS. Good to as far as I can generally see the little old California Ground squirrels.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kansas99 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 12:23pm
My guns are safe to leave scattered around the house.  They are all highly trained and know not to be running off and shooting someone.Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus51 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 4:57pm
99  that is a nice looking gun.
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 5:09pm
[TUBE]EWk2q68jC8M[/TUBE]
