Firestone 26 x 12 x12
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Topic: Firestone 26 x 12 x12
    Posted: 30 Nov 2016 at 3:48pm
I have a chance to buy a new set of Firestone 26x12x12 23 degree tires for a stock altered 716 6 speed that I am building. I was going to get a set of puller tires for it, but do you think if these were sharpened, that they'd work? We have predominately loose tracks. I was concerned that they'd dig a bit too much. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 5:53pm
23ยบ firestones are one of the best tires out there.  Try them first, before grinding anything away, is my advice...  Also try them at various pressures, to match track conditions...Thumbs Up
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2016 at 12:14pm
We put a lot of those on for the guys and gals pulling in past years. I don't remember any of them being cut, sharpened, or ground down.
ac720nut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac720nut Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2016 at 1:00pm
Used them for years back then there weren't all these different tires to chose .
I'ld chose a set of stones over anything out there, any Idea how old they are?
The older harder a tire is .
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2016 at 7:10am
They are brand new, apparently. Guy doesn't want them. He is going to use puller tires.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2016 at 10:36am
ive got them on a cub kadet with 12.1/2 inch wide wheels running onley enought air to keep the valve stems in the holes mine are new and soft and un cut when i pulled last it didnt hook like the cut one s just spined out  so i think i will have to cut mine .   i am watching for a b112 to tranplant all my puller parts to
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2016 at 10:58am
I have a 716 and a B110 that I will be pulling with too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac720nut Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2016 at 5:42am
HudCo, you might check with CasinoJim on simple tractors, he 's out your way and seems to be able to find a lot of those tractors. just a thought if your looking.
This page was generated in 0.101 seconds.
