Fire went out
Juiceman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Juiceman Quote  Post ReplyReply Direct Link To This Post Topic: Fire went out
    Posted: 23 Apr 2014 at 9:11pm
Just got our wd45 running yesterday after a total rebuild with different crank, cam, rods and pistons, head, etc. She's running a little rich and smokes a little. Dad drove it over to a friends house, to wire in lights and do little odds and ends on it. On the way home going up the hill it smoothed out and ran great for like 10 seconds, and then it started surging, like it would be wide open and then it would do nothing, wide open, etc.. Finally it quit. So after realizing she wasn't locked up, the dodge and i pulled dad the rest of the way home. Im thinking maybe we have a fuel delivery problem, since it was surging like that, but i guess it could be electrical. Haven't checked it out yet, just shoved it back in the garage. what do you think it could possibly be?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2014 at 9:32pm
surging could be fuel... or could be the coil got hot and died.. Try it again the the morning when the coil has cooled off... check spark if it dont start.
IL-D17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IL-D17 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2014 at 11:23pm
Check the float level in the carb. Its possible its set a little high which is trying to flood it causing the richness or smoking. When you started up the hill the angle of gas level in bowl changed letting the needle shutoff the flow to bowl allowing it to run well for the short bit it did. IDK, just a guess from what info you've give. Goodluck
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2014 at 2:40pm
Maybe it's just a flatland or downhill tractor!
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2014 at 6:49am
I had one mess me up bad last night.... I went out to crank our puller to load for today. She fired right up, ran good for about 2 seconds and began to miss, then finally blowing fuel all over me it went to one cyl. I shut it down. I pulled the plugs, they were soaked, spinning the engine there was no fire.
  MSD equipped, I tested it first, checked good, O ohmed the coil, it only checked 1.5, used to be 4.5. I replaced it. I now had fire out of the coil wire but couldnt get it to the plugs.
  Long story short, I had just replaced the cap and button before Tunica's southern nationals, the tractor had made about 10 or 12 passes on it so wasn't lookin at them.  The problem was solved when I put another rotor button in... Grrrrrr, spent hours checkin voltage, etc. Sometimes and most of the time the simplest things fix em. Don't look to hard!
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Juiceman Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2014 at 7:49am
Well simple it was! It ran out of gas. Never dreamed it would burn three gallon in less than an hour. Ive never been around anything but stock engines, so this was a very big surprise. Lol and glad its going to cost 24 dollars an hour to run this thing... Not!!    Haha oh well it runs meaner than a snake! We had a rear main leak really bad, so pulled it back apart again. Should have it back together by the end of next week and hopefully get it on the dyno the 12th of this month. And pull the 17th. We r missing a club pull today, but its just bad luck. Lol
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2014 at 1:48pm
I haven't bought any recently, but Napa or Echlin parts seam to be the best quality,  Brass terminals in cap and rotor.  The aluminum parts from many suppliers are just plain junk....that said I think the cap on my AC is a junk one, I better put a new one on before I hook it the end of the month.
I'm really not a fan of MSD boxes on these low speed 4 cyl engines.  I do like MSD stuff, but I just think it's over complicating something that is already pretty simple.
Juiceman, double check the flange end of the crankshaft, some cranks have a wick in them (you'll see a cork or black solid crud in the center) and others are solid.  It could get burned out when welding the main journals back up or be falling apart from many years.  If it is, drill and tap and put a pipe plug in the end, maybe just do it anyways for good measure.  If you are unable to drill and tap it for a plug, simply dig stuff out and put some silicone or epoxy in the hole.
Don't worry about fuel.  We're probably around $3500 per hour for fuel (5-6 gal in 12 to 15 seconds at $2.75 per gal) if I figure it out...but we only run a few minutes per season at that fuel rate.  Fuel's cheap, it's the maintenance and traveling that sting.
Edited by wi50 - 03 May 2014 at 2:04pm
