Fire rings D17 diesel
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Topic: Fire rings D17 diesel
    Posted: 28 Aug 2025 at 7:20am
Does anyone happen to have a set of fire rings that MACK made laying around?  I regret never getting a set from him before he passed.
ryan
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2025 at 3:47pm
Use hylomar on the whole gasket, did that on my d19 diesel and never had a problem with it for the last couple years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2025 at 4:06pm
Did you use the spray? I’ve heard of it but usually use copper coat on head gaskets.
ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2025 at 5:02pm
Yes I did, it’s like $40 bucks on Amazon for a 16oz can
Here’s a link to where I got it..
https://www.amazon.com/Hylomar-HUBRA01-Polyurethane-Sealant-Aerosol/dp/B0086AJ75U
Another plus is you can supposedly reuse the gasket if you ever pull it off again.
Haven’t had to pull the head I put it on again so I don’t know if that’s true.
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2025 at 6:57pm
Does anyone remember what Mack had the fire rings made from? I got a set but i cant remember.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2025 at 8:21am
   SealTec out of IL will make you any size ring you desire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2025 at 5:10pm
I know he made them thicker than stock. But not sure what he made them of.
ryan
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2025 at 10:34pm
" I regret never getting a set from him before he passed. "
That makes two of us.
Don't think I would reuse an old head gasket on a diesel...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2025 at 11:31pm
Here is some of his own words…
I’m not for sure if that’s what he made them all out of but we was dealing with a copper head gasket.
ABablerNIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ABablerNIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2025 at 9:05pm
   Think we’re going to have to go this route. Have a wd45 diesel that can’t seem to keep her head down with ARP studs to boot. D-17d engine repower.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2025 at 8:53am
   For some reason he will want INSIDE diameter, then measure  used compressed  gasket, I think I went 40,000 thicker then the gasket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ABablerNIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2025 at 8:18pm
Thanks for the info!
