  FAQ FAQ  Forum Search Search  Events Events  Register Register  Login Login
Finally installed for fit
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Finally installed for fit
    Posted: 24 May 2010 at 9:39am
Hi Guys,
Well I finally got a day of no rain off and installed the quick attach; I was correct, the overall width was good but the inside dimension was wide on the arms.  A good 3/8 to 1/2  inch narrower between the arm plates or add 3/8 to the inner arm plate overall width to narrow the mount slots.  With my loader being 'tweaked' a taste and the bucket flanges a total mess I did come reasonably close.  I will get a few thick spacers or heavy washers and shim it up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 9:42am
I did center drill, cross drill and tap the pins they sent for grease, seemed a better idea than trying to drill the arm eyes.
Kurzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurzy Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 9:47am
Nice job done! This winter I did a job on an AC 6140 with a AC 450 loader. I put forks on with its own mount.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 4:21pm
I am adding a QT bracket to the back of the OE bucket then ordering pallet forks and a bale spear head, I am hoping to see if I can construct a small tree shear to hook up on it so I can 'snip' thorny locust scrub.
