Final Drive Ratios
cadgent View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cadgent Quote  Post ReplyReply Direct Link To This Post Topic: Final Drive Ratios
    Posted: 28 Aug 2016 at 10:09pm
Does anyone know the difference in the D17 series 4 & 180 Final drive ratios?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2016 at 6:30am
5.43 to 1 on D-17 and 5.85 to 1 on 175-180-185.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2016 at 9:18am
I believe the 185 has one tooth less on the pinion to bull gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2016 at 9:41am
The internal gears don't interchange. The 175-180-185 final drive gears are much wider than a D-17.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cadgent Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2016 at 10:12am
Are 170's the same as a D17 IV?
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2016 at 10:17am
Working out the math, 14 tooth pinion to 76 tooth ring gear is 5.428571:1 close to 5.43. 13 tooth pinion to 76 tooth ring gear is 5.846154:1 close to 5.85.
Gerald J.
