Final drive housing similarities. D17 |
Dragfluid
Joined: 30 Nov 2024 Location: Pillager, MN Points: 24 |
Topic: Final drive housing similarities. D17Posted: 12 Dec 2024 at 12:22pm |
Series III D17. One of the final drive housings (cast part) needs to be replace, once I start working on it. There's a guy that has a crapload of WD and WD45 parts that he's trying to get cleared out because he's moving. (in Elk River, Mn) Is the '45 housing the same? I can swap the gears if they're different. Thanks!
Series III D-17
Many others in my life. |
Posted: 12 Dec 2024 at 12:29pm |
Not the same. What part are you wanting to change?? The tube?? or the bull gear housing ?? All the gears inside are different tahn a WD45.
Dragfluid
Posted: 12 Dec 2024 at 1:58pm |
Both the bull gear housing and the tube. Both are broken at the flanges. I had welded it up when it happened many moons ago, but I'd like to replace them with non molested parts. Thanks! Guess I need to search some more.
Series III D-17
Posted: 12 Dec 2024 at 2:20pm |
Series 3 and 4 should be the same parts.
Dragfluid
Posted: 12 Dec 2024 at 3:03pm |
OK, thank you.
Series III D-17
Joined: 11 Sep 2009 Location: illinois Points: 88627 |
Posted: 12 Dec 2024 at 4:12pm |
could you replace BOTH with WD45 swing units ?? ......price if right, if they will fit..
Posted: 12 Dec 2024 at 5:12pm |
Series 3 has band/disc brakes. WD-45 has drum brakes. The pinion gear/brake drum shaft iS completely different.
