Field drainage tile |
scott
Joined: 12 Sep 2009 Location: michigan Points: 2769 |
Topic: Field drainage tilePosted: 29 Apr 2024 at 10:48am |
I own a deep 40. 1/8 mi wide by 1/2 mi deep. The very back 10 acres (of woods) has a county drain ditch that runs thru. Getting ready for the field tile crew we cut a path thru the woods to the ditch to run the main. I remember the 'panic' of 'wrecking' such a big area of my trees, the saw was in my buddies hands and he went to town clearing a path.
25 years later, well probably started 5 years ago, the end of the field was too wet to do anything with. Every year the spot got larger until this year when the woods is flooded and the field is swamped. The tile is plugged and only dropping a 1" diameter stream off the end of the pipe. The neighbor is an excavator. I got him back there last year and he exhumed a 8 foot long plug out of the tile. Tree roots. The obvious culprit was 20, maybe 25, feet away. This year was more of the same, different spot only 100 feet or so before the ditch with the offending tree probably almost 35' away. The tile went from dumping an inch of water to like 4 or 5 inches of water... But... I've had it. I'm going out this spring and cut down every tree within 50 feet of the tile. Screw the deer and the squirrels we are going big. Probably have the excavator back to push up all the stumps so I can do something with the open area. Years ago I wish I had advise from a FOG saying cut (more of) those trees down. Those roots will travel a long ways and infiltrate a solid, no perforations, drainage pipe. Feeling bad for the trees we cut was stupid, I still had tons of trees left after we cut the initial path and then the sun got thru and suddenly we had grass growing in the woods, yes with deer and squirrels. Even the tile guy never got 'excited' by my less than ideal situation. Years later it seems the correct answer has become to clear a 100 foot wide swath and get the roots waaay back. I wish I had understood that back then... |
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34616 |
Posted: 29 Apr 2024 at 2:31pm |
Or go along the tree line with a root cutter every so many years
dkattau
Posted: 29 Apr 2024 at 7:00pm |
Depending on what kind of trees, 100 feet might not be enough. If it’s cottonwoods, you might think about going further.
Pat the Plumber CIL
Joined: 11 Sep 2009 Location: Springfield,Il Points: 4988 |
Posted: 30 Apr 2024 at 7:41am |
Tree roots should not be able to grow through solid pvc that is properly glued and installed. Now when a crack or opening is available roots can grow through a hairline crack . Problem today is high quality schedule 40 pvc is expensive. About 50 dollars for a 10 foot length. They do come in 20 foot lengths with bell ends but have not priced any lately. There are cheaper pipes but you get what you pay for.
1964 D-17 SIV 3 Pt.WF,1964 D-15 Ser II 3pt.WF ,1960 D-17 SI NF,1956 WD 45 WF. |
scott
Posted: 30 Apr 2024 at 9:34am |
The 'solid' pipe thru the woods is a flexible black 6" corrugated pipe that was laid in place by the Tile Machine. If there were stones or whatnot I could see where it might have been damaged slightly knifing it into place.
ac fleet
Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
Posted: 30 Apr 2024 at 10:38am |
tree roots have no problem going thru that flimsy black plastic tile!! It comes either slotted OR solid and trees will go thru either one in a heartbeat.
IF you use solid then you have to step up to sewer grade white thick wall stuff and sit down when you see the price of that stuff!
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8402 |
Posted: 30 Apr 2024 at 8:27pm |
Why not just have an ‘open ditch’ or a concrete lined open ditch in the woods? Or better yet a ‘waterway’ leading to the county ditch?
Edited by Lars(wi) - 30 Apr 2024 at 8:30pm |
bobkyllo
Joined: 14 Sep 2009 Location: minnesota Points: 1568 |
Posted: 02 May 2024 at 2:42am |
It might be cheaper to run a new main but this time run a few bare cooper wires along side the tile. The copper wire will keep the trees from plugging your pipe
scott
Posted: 02 May 2024 at 11:22am |
Lars, that would work. It would be a deep ditch and cut the woods in half.
Bob, the idea of a new main thru the woods has crossed my mind. The tube is knifed in with a tracked tile installation machine, there would be no way to get the copper wire in.
LicBarrett
Posted: 15 May 2025 at 7:27am |
I've had similar drainage issues and found that hiring a Gutters contractor who also understood tile layout really helped. They were able to suggest slight grade changes and properly route surface runoff so it didn’t overload the tile system. Sometimes the problem isn't just underground—water buildup from roofs and yards feeding into one low spot can throw off the whole setup.
Edited by LicBarrett - 10 Jun 2025 at 4:16am |
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3131 |
Posted: 15 May 2025 at 8:39am |
I fell for you. I like my trees. Just put in a little tile here. 40' form the edge of the field where those little short annoying willows grow. Tile said get those cleared out fast or there will plug the tile in a hirry looking for water. even 40' away.
I used to hear that the trees roots go about as far as it's crown. |
scott
Posted: 16 May 2025 at 2:08pm |
The update is we got the trees cleared back 75' from the tile main last year and the end of the field dried up this year, it must be working!
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3670 |
Thanks(1)
Posted: 17 May 2025 at 10:43am |
LarsWI, has the right idea (surface ditch thru the timber). No concrete. Why? Because gravity always works for an UNOBSTRUCTED downhill grade FOR WATER.
Tree roots inside the timber are your friends. The smaller shrubs, saplings, & grasses can compliment trees ONLY during off seasons & pre-seasons. As the optimal Tree season takes over, most smaller plants will struggle to compete in a solid wooded timber setting. Thicker tree leaf canopy quickly reduces photosynthesis. And tree roots dominate soil nutrients/moisture. So if a ditch is excavated, annual MAINTENANCE (bush hog) is crucial to keep small trees from re-capturing that vacant ditch area. The optimal bush hog season will probably revolve around area’s droughtiest month(August?). Mowing then will hit smaller plants hardest with a dramatic set back or fatalities? Or in the case of perennial grasses, mowing can improve scattering it’s seeds for its upcoming fall germ/growth. |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35664 |
Posted: 17 May 2025 at 4:10pm |
Willow and Swamp Oak will run a foot of New Root to a source of water Per Day.
