Fiat/Allis 16B |
Page 12> |
Neegan
Joined: 09 May 2022 Location: Moncks corner, Points: 29 |
Topic: Fiat/Allis 16BPosted: 09 May 2022 at 5:42pm |
New to this forum, thought I could get some answers here. I'm looking at a old 73-74 ( I think) 16B and was wondering if any parts are still available for those old machines.
I hate to see the ol' dozer be sold for scrap and would like to bring it back to life, been sitting for around 20yrs. Thanks
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 10 May 2022 at 7:32am |
some parts like gaskets and orings, thermostats etc still available at minnparr, but for most larger hard parts it will be salvage yards.
Neegan
Posted: 10 May 2022 at 8:49am |
So there is nothing available for final drives, transmission, etc but salvage yards? I may have to rethink my plan.
Joined: 11 Sep 2009 Location: illinois Points: 90636 |
Posted: 10 May 2022 at 8:52am |
Posted: 10 May 2022 at 8:57am |
Barry.... Allis did not make bearings, filters , or hoses... So MOST of that kind of hardware can be bought from others.... If you need a SHAFT or a GEAR that was specific to ALLIS, then your going to the scrap yard..... Tracks , rollers, chains are possible to purchase at scrap yard, or you might be able to "modify" and switch to some CAT or CASE size.
Neegan
Posted: 10 May 2022 at 9:31am |
Thanks for the link and the information. I just don't want to start something and not be able to finish it. Once I figure out how to post a pic on here I will.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35593 |
Posted: 12 May 2022 at 4:39am |
I looked at a 16b but needed rails rollers and segments, was nothing I could locate for it in the US. Were some pieces in Europe some in AU but cost to ship excessive. Cat never used the size rails and Deere on only a limited few also obsoleted.
CAL(KS)
Posted: 12 May 2022 at 3:53pm |
just watched a youtube video today of someone recently loading one on a trailer for scrap
. it started and run but was low on trans oil presumably and wouldnt move. but looked like decent UC what a shame. would have been a great parts machine
Neegan
Posted: 12 May 2022 at 5:12pm |
I'm going to roll the dice and try and get it going. I made a deal with the owner that if I got it running and it would move so I could drive it on a low boy I'd buy it for the scrap price. The owner said everything on the ol' dozer worked when he parked it.
Neegan
Posted: 18 May 2022 at 12:02pm |
Can anyone help me out here? I'm looking for the part number for a starter for this HD16B serial number 19S13130. The owner can't find where he put the old starter.
Thanks
CAL(KS)
Posted: 18 May 2022 at 2:24pm |
73117237 1 MOTOR, starting ("Delco-Remy" #1113898)(Standard)
70620350 1 MOTOR, starting ("Delco-Remy" #1109986XHeavy-duty try this from powershift tractor book. didnt check the direct drive book but guessing the same and minnpar has oem manuals online. |
CAL(KS)
Posted: 18 May 2022 at 2:29pm |
both numbers replaced by 74396759 minnpar has in stock
Edited by CAL(KS) - 18 May 2022 at 2:29pm |
Neegan
Posted: 18 May 2022 at 4:44pm |
Thank you for the help. I haven't purchased any manuals yet because if the dozer does not operate like the owner said, then I'm not buying it. If I buy it I will for sure order parts and service manuals.
Neegan
Posted: 18 May 2022 at 5:08pm |
I looked that starter up at minnpar but not sure its for a 17000 MKII 844 engine.
DMiller
Posted: 18 May 2022 at 5:50pm |
Should be a 50MT Delco 24v, could be a 40MT 24v differences will only be bendix tooth count.
Neegan
Posted: 20 May 2022 at 4:53pm |
I have another question, I know this is a 24 volt system but I'm a little confused by the cables in the battery box on this dozer. There are 2 positive cables coming from the kill switch and it appears 2 ground cables that run under the dozer. I dont see how this configuration could result in 24 volts. What am I missing here? Thanks
Codger
Posted: 20 May 2022 at 6:36pm |
Parallel cable routing to carry starting current most likely. There were original either two 12VDC batteries wired in series, or four six volt batteries. If four six volt batteries these were all wired in series. What this means is one positive pole ties to the next negative pole of the next battery. You then have your last positive pole tied to the disconnect switch, and the negatives to chassis ground. I am assuming a negative ground system. If positive ground, the leads are reversed. Basically, batteries wired in series are additive in voltage. Batteries wired in parallel are the same in voltage but much greater current reserve.
If the engine has an alternator, it is most likely negative ground. If a generator, most likely positive ground.
Neegan
Posted: 20 May 2022 at 9:40pm |
Thanks, I just don't get why there are 2 positive cables going to the kill switch, just seems odd.
Codger
Thanks(1)
Posted: 20 May 2022 at 10:18pm |
You could run a single cable but much larger than two smaller ones serving the same purpose. Someone along the line probably replaced the original cable as I don't believe a parallel setup was "as built", but rather probably a single 2/0 cable. Whole lot of things get changed in the lifespan of machinery.
Neegan
Posted: 21 May 2022 at 4:12pm |
Got the cables sorted today and also bought a new starter for the dozer. Tomorrow we put on the starter and hookup the batteries then see if this ol'dozer will start and move.
Neegan
Posted: 22 May 2022 at 5:22pm |
Well the rain shut us down today, hopefully tomorrow will be the day.
CAL(KS)
Posted: 23 May 2022 at 7:30am |
book shows 2x12 in series with single cable. kill is between negative post and ground to tractor.
Codger
Posted: 23 May 2022 at 7:51am |
Placement of the disconnect wouldn't make much difference in the application. Either removes the potential that exists of a completed circuit.
Neegan
Posted: 23 May 2022 at 8:56am |
The owner used the two cables from the kill switch as the jumper between the two batteries.
CAL(KS)
Posted: 23 May 2022 at 10:00am |
Neegan
Posted: 23 May 2022 at 5:05pm |
Today we had to sort out some bad cables after getting the starter on which took a bit. But we finally got the dozer to start but would only run on ether, we will check the rack on the pump tomorrow to see if its stuck. I don't know why it could be stuck after only sitting 15yrs or so.
Codger
Posted: 24 May 2022 at 7:38am |
I'm assuming a Bosch pump? Any experience getting those freed up when the rack is stuck, or plungers are stuck in the barrels? I usually remove the delivery valves from the top of the P&B's and fill them with mineral spirits keeping them full for a few hours. Then start to gingerly work with the rack and plunger return springs to free things up. The spirits will break the varnish that has adhered the plungers to the barrels and hopefully they don't score when working again.
Just as I've done for many years and you may have another/better way.
Neegan
Posted: 24 May 2022 at 5:20pm |
Thanks Codger, still no luck today. Do you have any pics or a diagram of just what you did to get it freed up? I'm not a mechanic that's why all the questions. Thanks
DMiller
Posted: 24 May 2022 at 6:46pm |
IF the Injector pump has a Rotary head that appears similar to a Gas Engine Distributor then it has a PSB pump, Parts are currently UNOBTANIUM, fully discontinued by American Bosch.
Codger
Posted: 24 May 2022 at 6:58pm |
Not really as I've been into so many of them through the years messing with antique equipment and trucks. However, and inline pump has a barrel and plunger for each cylinder. Many pumps require removal of the governor assembly to work with the rack which rotates the barrels increasing or decreasing the effective stroke of the plungers by changing spill timing. If the rack is indeed frozen in place, remove the injection lines and screw out the large plugs the injection lines attach to on the pump. Under these will be springs and discs or an apparatus that serves as the delivery valve. Ensure to keep these organized as to which placement they came from. The plungers are now exposed on their tops. I take compressed air and blow these clear of any liquid present, and then fill them with the mineral spirits allowing it to dwell. The fitment of the plungers to barrels is in the microinches range so leakdown if any will be very slow. Rapid level drop is usually a worn out pump.....
After this solution sets a spell, try to work the rack fore and aft gingerly. If the side plate is accessible you can remove it and see if any plungers are "stuck up" in their barrels. If so, pry them down with a screwdriver as easy as you can. Don't "hammer" on them as you don't want to hurt anything. When all are down and touching the camshaft, rotate the engine and see if the plungers all ride up and down or stick again. Repeat, repeat, repeat, until all is freely operational. Once the plungers are free, the rack should be as the rack rotates the barrels in the pump housing. With everything free and moving, reassemble and test. If engine is down on power, pump is most likely worn out. I strongly suggest you get some printed matter to have in front of you before opening anything up. I also cannot stress cleanliness more firmly either. Dirt or foreign matter in the fuel system will cost you. Good luck. I don't mind the questions. It's how we learn.
Page 12> |
