fiat allis 10c dozer
DoubleFarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DoubleFarms Quote  Post ReplyReply Direct Link To This Post Topic: fiat allis 10c dozer
    Posted: 08 Dec 2023 at 4:51pm
I have a fiatallis 10c dozer,  looking for the push button start switch on the dash, has 3 wires going to it, any body have a part no. for the switch.  Thank You
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2023 at 6:23pm
John Deere used a 3 terminal start switch on some older gas tractors... The third terminal supplied power to the coil ( around the RUN resistor) for startup... After starting, the coil was supplied power thru the resistor at a reduced voltage... IM not sure what a 3 terminal switch would do on a diesel... Power to "something" only when cranking, then off ..
Steiner Tractor.....
Edited by steve(ill) - 08 Dec 2023 at 6:25pm
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2023 at 6:30pm
Many of those old tractors had an insulated, (non grounded) magnetic switche to engage the starter. One applied both power, and ground to the switch. I've seen this more on Dyer type drives than Bendix types however.
That's All Folks!
