F&H wheel weight ?
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: F&H wheel weight ?
    Posted: 31 Mar 2020 at 7:21pm
Any idea of what # 162 would fit ? They claim 150 #'s per "set" ?? 2 pairs on my local craigslist.
steelwheelAcjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steelwheelAcjim Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2020 at 7:41pm
I always felt they were a "universal" weight that would fit most tractors with a cast center hub, or round spokes with J-hook bolts. What would you like to put them on?
Pre-WW2 A-C tractors on steel wheels...because I'm too cheap to buy tires!
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2020 at 7:44pm
A 180
ICTRCTR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ICTRCTR Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2020 at 9:02pm
161 and 162 f & h wheel weights sandwich together were found mostly on wc allis but will fit different tractors as well.( one fits inside the other )
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2020 at 9:03am
They will fit your 180. Here's a pic of my (Dad's) 185 with a set. 161's on the inside, 162's out. I did have to index the lug-bolt heads to get them on. They weigh about 150 lbs. apiece.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2020 at 9:16am
162s are a universial weight I have a set on my wd 45 if your going to stack them you want to put the 161 weights on first they have a lip to center the other weights. I had problems with my 162 without 161s under them I cured the problem by adding another set of bolts and getting real tight.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2020 at 2:49pm
I have a D17 with the 161 weights
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2020 at 3:52pm
The 161 also have a slightly larger center hole to get a socket onto the six nuts holding wheel center to hub on the WC's
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2020 at 9:13pm
I did not know F&H made a #161 and a #162. I just thought an F&H was an F&H. I'll have to go down to the machine shed and look for a number and see what I find. Great conversation! Learn something everyday.   Thanks for bringing up this discussion. Much appreciated!
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2020 at 9:36am
Info on weights from the Knowledge section.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2020 at 8:37am
Anyone have a front set of weights that match the rear weights on the WD45?
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2020 at 10:36am
I would like to find a set of those myself Lon. Have seen them in the book but never in person. Probably a guy in Texas has that several sets.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2020 at 8:43am
Never saw the front ones in person either. I found my rear set and I didn't know what I was looking at, but bought  them anyway as weights are good property. Then I found them in the book and found they are 375 pounds each. Way cool to have a full set.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2020 at 9:23am
Here is a pic from the 'Deep tillage tools' manual. Lists the front weights as 157 Lbs., more than twice as much as the more common 'doughnut' weights.
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2020 at 9:08pm
Hi Dakota Dave:  I checked my F&H weights and they all have the #162.  When you say this number is a "universal" weight, does that mean they would fit the standard rear wheels on the D-15 and D-17?  Nothing special to do with them?  Thanks in advance for any thoughts!
Pete from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete from IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2020 at 12:25pm
I know on a D17 you need a 161 weight first (smaller diameter) then you can put on the 162.  The 162 will hit the bolts that stick out for the power shift wheels.
