Fence row D14 |
Page <12 |
Dave(inMA)
Joined: 12 Sep 2009 Location: Grafton, MA Points: 2400 |
Posted: 22 Jan 2020 at 9:55am |
My CA has 1/2" square eccentrics. I welded two 1" six point 1/2" drive sockets together with the square 1/2" drive openings facing out...one end for a breaker bar, the other for the eccentric.
WC, CA, D14, WD45
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4284 |
Posted: 22 Jan 2020 at 9:19am |
On those eccentrics; I have a (I think) 20mm 1/2" drive socket welded to a 3/4" adapter. Works good on those extra tough ones!
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3253 |
Posted: 21 Jan 2020 at 11:50am |
Gotta wonder if a 3/4" socket fit the eccentrics ? My D 15 seems to be 25/32 . Never did find out for sure . Thanks
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8662 |
Posted: 21 Jan 2020 at 10:32am |
John, Guys,
Yea this is rough around all the edges, smokes some on start up. But it still moves and functions.
I have run these old chains some and they didnt seem to bother the tires. They are so worn and smooth or maybe sharp in some areas. He was happy to get them, We spent some quality time getting those rims moved and the chains on. All in all a good couple hours. I beat on the heads of the eccentrics with a 10 lb sledge several dozen times which may have helped too? I was very surprised that we got the eccentrics to turn. It cost a cheap socket and a 1/2 inch ratchet before they all moved. I told Matt he was pretty lucky as these typically have to be removed from the tractor. He should buy Loto tickets! Regards, Chris |
Dave(inMA)
Posted: 20 Jan 2020 at 9:09pm |
Nice, Chris. It's always fun to watch you reclaiming another old AC!
Dave
WC, CA, D14, WD45
john(MI)
Posted: 20 Jan 2020 at 8:41pm |
Is that the type of chains that will tear chunks of the cleats off of the tires? Or does that only happen if they are loose?
Boss Man
Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 617 |
Posted: 20 Jan 2020 at 8:39pm |
Nice Tractor. Looks like something I would drag home.
Sugarmaker
Posted: 20 Jan 2020 at 7:32pm |
Folks,
Matt needed some chains and some help today with his D14. I supplied him with some very worn tire chains that had been used for many years on WD's. When we started looking the spin out rims were not out away from the fenders far enough so we spent a hour or more getting the three eccentrics per wheel loosened and he made some plates for wheel stops. Stop for wheels, add ed both sides on the rail. plate with bolts through them. Looked like this farmer fix was going to work ok. Installed the chains then cut some off each to fit the tire. Some bungees and it was ready to plow snow. He said it worked much better with the chains! Regards, Chris |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 05 Jan 2020 at 6:43pm |
Late model D14s do not have the guard on the hand clutch button either. Nice straight tractor there. She should clean up nicely.
DennisA (IL)
Joined: 11 Sep 2009 Location: Ridott IL. Points: 2077 |
Posted: 05 Jan 2020 at 6:35pm |
The 28" wheels was a factory option.
Thanks & God Bless
Dennis |
Alex09(WI)
Joined: 15 Mar 2012 Location: CECIL WI Points: 1777 |
Posted: 05 Jan 2020 at 6:11pm |
No, they are far easier to change. You need a hoist to hold the axle housing, with or without the tire attached, when you slide the axle housing out of the trans/differential housing. 4 bolts hold the axle to the transmission. No rusted brake pins to mess with. The brake drum will stay with the axle in the axle housing. The 2 brake shoes will be attached to a plate that stays on the trans housing similar to the drum brakes on 80's/90's trucks. Once you have the axle off it will be practically self explanatory. Be sure to change the axle shaft seal when you have the axle out.
www.awtractor.com
A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25272 |
Posted: 05 Jan 2020 at 5:59pm |
looks like nice rubber ! so find some combine rims ! I KNOW they fit !! Yes, brakes are 'inside'..if you want practice...hint,hint.... There's an axle seal that goes,allows diff oil to 'lubricate' the shoes. Also the ram cylinder seals can go or the hyd hose inside the diff. The telltale is having to add hyd oil.... If you open it up for that, have a hyd shop make the hose WITH 1 swivel fitting, it'll make reassembly go easier as the AGCO part(still on my shelf) doesn't swivel...
Sugarmaker
Posted: 05 Jan 2020 at 5:55pm |
Dave,
Thanks! So are they of similar difficulty to change? Compared to a WD series tractor? Regards, Chris
Sugarmaker
Posted: 05 Jan 2020 at 5:52pm |
Thanks John!
I am working on him to do some horse trading! Maybe bring it to my house and leave it for a while. I mean he does have my TD6 dozer at his place!:) Seems only fair and he is a IH guy! I am going to have a real nice set of Firestone 13.6-28's from the WZ, that would bolt right on this D14! Regards, Chris
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55299 |
Re the brakes, they are inside the axle housing, real close to the diff. You have to pull the FD housing, then the axle housing, to get to the brake drums and shoes...HTH
john(MI)
Posted: 05 Jan 2020 at 5:46pm |
Yes, The WD Wheels will fit on the D14. Any 8 bolt rim should fit.
Sugarmaker
Posted: 05 Jan 2020 at 5:41pm |
Folks,
My friend Matt pulled this tractor from a fence row a couple months ago. Its rough, but functions. He belted it up and buzzed some wood with it yesterday. Today was a conversion to 12 volt alternator and coil, and battery. Also he worked on the 3 point hitch system. He got the arms with the pivots from another of his tractors (English Massey). Some pictures: Serial number- D14 5868 ![]() Matt installed the tool box that was on one of My Uncles tractors: ![]() Both rear fenders are rough with crinkles and the left one was welded where it had rusted out at the bottom. Seat is in pretty bad shape but like the fenders still hanging in there! ![]() ![]() Where are the brakes on these? Inside the trumpets? Still has some brake left. ![]() This rim is not good but has had some repairs around the valve stem. Power director has good snap. No guard on the PD lever indicating a early model too ![]() Will WD rims fit on a D14? ![]() Added a angle and pins for the three point: ![]() Top link bracket assembly fabricated: ![]() Regards, Chris
Edited by Sugarmaker - 05 Jan 2020 at 5:47pm |
Page <12 |
