felt seals
david s View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote david s Quote  Post ReplyReply Direct Link To This Post Topic: felt seals
    Posted: 20 Nov 2013 at 1:46am
anyone knows where one might find front wheel felt seals for a dd grader ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2013 at 4:45am
Try a hydraulics shop for bulk felt as it was used for wiper seals in cylinders, that is where I found the last I bought for a antique truck that was set up similar.
Post Options Post Options   Thanks (0) Thanks(0)   Quote david s Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2013 at 8:05am
thanks I never thought of a hyd shop
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2013 at 8:57am
I found seals with multi-lip synthetic compound to use on front hubs - replaced the felt seal with a modern design that both excluded dirt but also moisture.
