Fat backs anyone?
 Rating: Topic Rating: 1 Votes, Average 4.00  Topic Search Topic Search  Topic Options Topic Options
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Topic: Fat backs anyone?
    Posted: 17 Feb 2023 at 11:21am
I have a pair of gleaner fatback rear wheels that I'm going to advertise for sale. These are off an early L combine. Other than the L, and maybe a G, I don't know if any other models even offered them. I don't think that they were even available for the later L series. Did any other manufacturers offer something like that? Deere or IH?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2023 at 6:26pm
In the 70s M&W made cast iron rims they called "Fat Fronts". These were primarily offered to put fatter tires on the heavy rims on the front of tractors. The sales literature also showed them being used on the rears of combines. Look closely on yours for a M&W logo.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2023 at 8:15pm
will they fit the fronts of any allis tractors ?  maybe instead of front wheel weights
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2023 at 8:54pm
I have an early M with cast rims is that what those are?
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2023 at 9:38pm
What tire size fit on them?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2023 at 10:23pm
These  cast iron rims use a 11.00x16 tire. The M gleaner does show them in the parts book, but they are a different number than the L. That size of rear tire seems a little big for an M. I think that they are a regular Gleaner wheel and not an M&W?? I can look closer for that. They might indeed fit some tractor front ends ,but the spindle dimensions would have to be the same. They must weigh 200 to 300 pounds apiece???? Clumsy as hell to move around especially with a flat tire.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2023 at 6:51pm
Lynn, is this what your gleaner fatback wheels look like? Single rib tire? This photo is copied from a Gleaner G/F/K sales brochure AED-196 7201(1972,January).  Imagine your L/M fatback is an 8 bolt pattern though?  The F/Ks had a 6 bolt wheels. Were the Gs an 8 bolt pattern?
Edited by AC7060IL - 18 Feb 2023 at 6:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2023 at 7:27pm
Yes and no. That is exactly what they look like. Mine have a multi rib tire on them,but any style tire tread would work as long as it's the correct size. They don't use any lug nuts,the wheel is milled for the bearing races, so it fits directly onto the spindle. Those early L and M combines just used a 6 bolt hub as did the G, if they had steel rims.Later production used an 8 bolt hub and I believe heavier spindles too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2023 at 10:05pm
Would those cast rims fit a tractor or is the spindle a different size?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2023 at 6:44am
The M&W ones would bolt to standard hubs, so they would work on both tractors and combines. I know they were available with the standard 6 bolt AG pattern, they might have also been available with the standard 8 bolt AG pattern.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2023 at 8:15am
The cast rims would fit on a tractor,or anything for that matter,as long as the spindle dimensions are the same. Measurements would obviously need to be taken.
This page was generated in 0.230 seconds.
