Faron's HD16 |
Steve allis dozer
Silver Level Access
Joined: 10 Apr 2011 Location: Australia Points: 232 |
Topic: Faron's HD16Posted: 30 Aug 2011 at 12:34am |
Faron's HD16
Steve allis dozer
Silver Level Access
Posted: 30 Aug 2011 at 12:36am |
Steve allis dozer
Silver Level Access
Posted: 30 Aug 2011 at 12:37am |
Steve allis dozer
Silver Level Access
Posted: 30 Aug 2011 at 12:38am |
Tad Wicks
Joined: 27 Mar 2011 Location: Shandon, CA Points: 2181 |
Posted: 30 Aug 2011 at 1:52pm |
There was certainly some time spent on this one and it paid off, it looks GRRRRRRRRRREAT. Tad
Kcgrain
Joined: 24 Sep 2009 Location: Wisconsin Points: 811 |
Posted: 31 Aug 2011 at 9:26am |
Looks nice what tractor is that out side in the window?
Faron
Posted: 03 Sep 2011 at 3:35am |
That tractor is a ford 8401 i can take a picture of it if you want
Edited by Faron - 03 Sep 2011 at 3:47am |
Faron
Posted: 03 Sep 2011 at 3:49am |
It will look better when i build a a/c cab and finish it all together.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42266 |
Posted: 03 Sep 2011 at 10:14am |
Looking at the rear sprockets and the weld on the ring you said you made . So if I get this right you took just the sprocket segments and welded to your own ring and then welded the ring to your AC sprocket spokes ?
I did the Cat D5 ring onto D6-9U sprocket and it took me quite a few tries to get it to stop cracking weld as the ring cooled while welding . Pre-heating both / then welding and hearing the ping noise as a weld cracked somewhere on the ring .
Kcgrain
Posted: 03 Sep 2011 at 10:53am |
Is this just a labor of love? Your doing a nice job on the restoration but the cost WOW.
We have a HD11B that we are doing that to, with some modern day conviences added to it, but we didnt go down as far as you have, well we didnt have to mechanically it was in good shape, but needed an engine and some work on the track tightner. The paint you used is that an old Caterpillar color I thought the AC were brighter, we matched the paint on out 745 loader to a PPG color and its brighter, but now I kind of like the color of yours. I see you added a muffler looks likeone off of a 4890 Case which is what we used on the 745 sounds great with it on.
Faron
Posted: 04 Sep 2011 at 4:26am |
What i did was make a ring drilled and machined it to suit the cat segments cut the old sprocket ring off then welded the drilled ring to the 16 sprocket hub if you look at the dozer picture you can see it fitted and i posted picture of the sprocket hub
Edited by Faron - 04 Sep 2011 at 5:29am |
Faron
Posted: 04 Sep 2011 at 4:38am |
The colour is new cat yellow the muffler is d7. I still have quite a few hours to go i have to put piolit operated hydraulic controls for blade rippers and tilt and build a/c cab fit rippers and blade
Faron
Posted: 04 Sep 2011 at 5:20am |
Edited by Faron - 04 Sep 2011 at 5:22am |
