Faron's HD16
Steve allis dozer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Topic: Faron's HD16
    Posted: 30 Aug 2011 at 12:34am
Faron's HD16
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2011 at 12:36am
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2011 at 12:37am
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2011 at 12:38am
Tad Wicks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tad Wicks Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2011 at 1:52pm
There was certainly some time spent on this one and it paid off, it looks GRRRRRRRRRREAT. Tad
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 9:26am
Looks nice what tractor is that out side in the window?
Faron View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Faron Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2011 at 3:35am
That tractor is a ford 8401 i can take a picture of it if you want
Edited by Faron - 03 Sep 2011 at 3:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Faron Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2011 at 3:49am
It will look better when i build a a/c cab and finish it all together.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2011 at 10:14am
Looking at the rear sprockets and the weld on the ring you said you made . So if I get this right you took just the sprocket segments and welded to your own ring and then welded the ring to your AC sprocket spokes ?
 I did the Cat D5 ring onto D6-9U sprocket and it took me quite a few tries to get it to stop cracking weld as the ring cooled while welding . Pre-heating both / then welding and hearing the ping noise as a weld cracked somewhere on the ring .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2011 at 10:53am
 Is this just a labor of love? Your doing a nice job on the restoration but the cost WOW.
We have a HD11B that we are doing that to, with some modern day conviences added to it, but we didnt go down as far as you have, well we didnt have to mechanically it was in good shape, but needed an engine and some work on the track tightner. The paint you used is that an old Caterpillar color I thought the AC were brighter, we matched the paint on out 745 loader to a PPG color and its brighter, but now I kind of like the color of yours. I see you added a muffler looks likeone off of a 4890 Case which is what we used on the 745 sounds great with it on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Faron Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 4:26am
What  i did was make a ring drilled and machined it to suit the cat segments cut the old sprocket ring off then welded the drilled ring to the 16 sprocket hub if you look at the dozer picture you can see it fitted and i posted picture of the sprocket hub
Edited by Faron - 04 Sep 2011 at 5:29am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Faron Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 4:38am
The colour is new cat yellow the muffler is d7. I still have quite a few hours to go i have to put piolit operated hydraulic controls for blade rippers and tilt and build a/c cab fit rippers and blade
Post Options Post Options   Thanks (0) Thanks(0)   Quote Faron Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 5:20am
Edited by Faron - 04 Sep 2011 at 5:22am
