Farmall AC Model C?? Seller says factory...
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Topic: Farmall AC Model C?? Seller says factory...
    Posted: 13 Dec 2023 at 6:39pm
Strange AC Model C seller says is factory experimental Model.
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2023 at 8:54pm
Strange is right! :O
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2023 at 9:49pm
does anyone recognize the front bolster off of another tractor ?  Where did it come from ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2023 at 4:22am
got a picture of the serial no?
LionelinKY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LionelinKY Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2023 at 4:25am
Steering support and shaft looks like a Farmall B/BN so guessing front bolster is same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2023 at 5:32am
Homemade creation, although pretty nice.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2023 at 5:55am
He's had that on Facebook for a while.  I've asked more than once for documentation it's an experimental and he's never provided it.  $4,500 seems steep for something he can't verify.
AaronSEIA
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2023 at 7:36am
Never seen  a Farmall bolster like that
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2023 at 8:10am
thats my point... if it is a "one of a kind bolster", he has that going for him... A serial number that it "ODD" or very low would help his cause.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2023 at 9:57am
Pre-production C tractors had hand brakes from the photos I have seen.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2023 at 12:21pm
Story's are easy ,proving them can be a task .
BillinAlberta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillinAlberta Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2023 at 1:39pm
I'd like to get a closer look at the step.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2023 at 3:32pm
Looks similar to aftermarket steps I see that bolt to the cross beam in front of the operator area by the clutch.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2023 at 4:27pm
Pictures of this "C" were posted here by "JerryMI" on1/15/07. He stated that it had A-C casting numbers. Although the post generated quite a lot of interest at the time, no one was able to say what it was.
I haven't seen a posting by JerryMI in many years....does anyone know whether or not he is still around?
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2023 at 5:25pm
Seller is in MI - so likely same tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2023 at 5:39pm
Pretty strange, but different!  I'm havin' a problem with the steering shaft as long as it is, there is no support at the steering joint.  I'm wondering how that steers without binding up. The only support for the steering is at the steering wheel. You would think there would be a steering support at least at the bellhousing area.... Weird....  Confused
Steve@B&B
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2023 at 9:09pm
That is some heavy shafting in there, so probably no need for supports.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2023 at 10:17pm
Ii had the same concern Steve.. If this was a "factory" design, i would think a support bushing would have been installed under the engine oil filter area, on the bell housing..
Richardmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2023 at 10:46pm
As I was reading this I am talking to Jeremy on the phone.
I will Try to get Jeremy to reply.
There was couple of these tractors built not just one.
Edited by Richardmo - 14 Dec 2023 at 10:48pm
This page was generated in 0.277 seconds.
