Fan clearance
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: Fan clearance
    Posted: 03 Nov 2025 at 3:43pm
Got the new D15 diesel in the shop to make some repairs over the winter and came across something I have not seen before.  The fan is much closer to the radiator shroud on the right side compared to the left.  I can easily fit my index finger between the fan blade and shroud on the left side, but can barely fit a pen on the right side.  Same goes for the height of the rad - the previous owner put spacers under the mounts to raise it.  If they were not there, I suspect the fan would not be able to spin without causing damage.
Everything looks original:  Perfex brand radiator, 4 blade fan and appears to have the original water pump (brazed on one spot).
Would anyone have any insight on this problem?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2025 at 4:00pm
My guess would be someone doctored the radiator and didn't get it right...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2025 at 4:25pm
The neck might have been worked on at some point, but the rest of the rad doesn't look like its been messed with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2025 at 5:17pm
Tractor rolled on its side once.
Skip, W.Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skip, W.Pa Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2025 at 7:10pm
Yes , as the Dr. said it was crashed at some point in it's life. No big deal just repair it as needed.
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2025 at 11:33am
I'd have to take a look at mine it may be off set.
I assume the roller over was a joke, because the core of that radiator would not be that straight in order to have shifted it that far and be in that nice of shape.
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2025 at 11:53am
Didn't say a roll over. Laid on its side lightly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2025 at 3:33pm
Laying on its side is possible but questionable in this case.  Seeing that the rad has less clearance on the right side, this would indicate that the tractor would have rolled to the right.  However, the sheetmetal and original Nelson muffler are straight as an arrow on the right side (and even on the left).  Surely a roll on the side would cause some sheetmetal damage if it was able to dislodge the radiator.
Could all of the sheetmetal had been replaced in a rollover or fall on its side?  Possibly.  But you can see all the paint matches.  Furthermore, seeing the creative backyard fixes the previous owner did to the tractor, I am sure he would not have gone through the effort (and expense) to find good original sheet metal for a diesel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2025 at 3:41pm
In the last 60 years, maybe the radiator couldn't be fixed and he settled for a (not so nice) used one?? It is what it is and it didn't leave Milwaukee like that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2025 at 8:22pm
Like Dr Allis said.Probably had it repaired at a half ass repair shop. That shroud is soldered on. I have seen them soldered crooked and off center. Not many quality oriented guys left. HTH Tracy
Post Options Post Options   Thanks (1) Thanks(1)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 27 minutes ago at 2:30pm
Problem solved!  Nothing wrong with the radiator.  It's the water pump!  The last person who put it on installed it incorrectly.  The bottom brace was secured to the wrong timing cover bolt, throwing off its location which caused the fan shaft to move up and to the right.  Who would have guessed?
I had to tear apart the front end of my other 15 diesel to figure it out, but it was worth it!  No major effort required to solve the problem!
Should be...
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 20 minutes ago at 4:37pm
Good job 👍
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 5 minutes ago at 7:52pm
Wow!! Who would have thought that! A fair bit of work but well worth to find the problem. Smile Smile
Most people would not have a twin nearby to compare. Lol.
Edited by Ed (Ont) - 12 hours 3 minutes ago at 7:54pm
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 60 minutes ago at 5:57am
It's always good to have a 'reference tractor' close at hand when working on these old girls! Helped me many a time. Also a good reason to own at least 2 of any model.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 25 minutes ago at 6:32am
Liked:  "Also a good reason to own at least TWO of EVERY model"............
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 11 minutes ago at 7:46am
Interesting find.
So without the shimming of the radiator on the one side would fan hit. That must have drove that guy crazy at that time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 2 minutes ago at 7:55am
Interesting, how to replace the leaking water pump, (I think) one would have to remove the radiator and grille shell to gain access to the water pump. So, after water pump replacement and upon reassembly of the radiator and grille shell, it doesn't fit the circle of the fan. The fix is to shim the radiator?? which used to be centered perfectly on the old water pump ??   Yeah. I guess that makes sense. Hope the tech went on to work at a Deere dealership.
Edited by DrAllis - 1 minute ago at 7:56am
This page was generated in 0.041 seconds.
